ls/vtec into 98 hatch
Old Mar 6, 2009 | 09:13 PM
nick32's Avatar
Default ls/vtec into 98 hatch
i have a ls/vtec b18b1/gsr that came out of a 95 integra. today i put the motor in my 98 dx hatch.
i thought the ls harness would work but turns out it doesnt.
I need to know what i need to do to get the wiring to work! i need my car running asap!
it is an OBD1 motor and i have an OBD2 car. I already have the obd2 to obd1 conversion harness. i just need to know what car harness i need and i think what distributor
do i need a obd2 b series harness? will a 99-00 civic si harness work? i have the d16y7 harness, would it work?
do i need a obd 2 distributor? or will the one that on the gsr head work?
i need to know what to buy adn i need it asap! if u have what i need let me know!
thanks
nick
Old Mar 7, 2009 | 06:35 AM
japspec-ek's Avatar
New User
Default Re: ls/vtec into 98 hatch
get a 98 ex 5 speed harness an a obd2 dizzy
Old Mar 7, 2009 | 07:11 AM
nick32's Avatar
will my y7 harness work if i just wire in vtec?
Old Mar 7, 2009 | 07:32 AM
nick32's Avatar
and will i still need a obd2 b series dizzy for the harness to work?
Old Mar 7, 2009 | 11:00 AM
nick32's Avatar
need to know asap so i can order parts!
Old Mar 7, 2009 | 01:46 PM
LB98ekhatch's Avatar
Banned
bump, i have the same engine
Old Mar 8, 2009 | 06:50 AM
citizenEK's Avatar
your OBD1 dizzy will work if you re-pin it with your plugs from ur SOHC dizzy. Also you should be able to use your Y7 harness and will most likely just have to extend a few plugs.
Then as long as you are using ur conversion harness you will not need to worry about missing the crank sensor on the oil pump with your OBD1 motor.
If you search you should be able to find how to re-pin your dizzy to OBD2. it's a very easy process that takes about 5 minutes.
T Thrash 09
14
Jun 8, 2010 06:15 PM
nick32
Mar 7, 2009 10:30 PM
fcfromhell420
Oct 3, 2007 09:35 PM
Hoppa
May 12, 2006 12:26 PM
