Oil Leak Hot spots
Old Mar 6, 2009 | 08:42 PM
prelude_5gen's Avatar
New User
Default Oil Leak Hot spots
I got many oil leaks in my 97, & so far I've changed out:
1. Oil Cooler O-ring
2. Distributor O-ring
3. Valve seals & spark plug O-rings
4. Cam seal plug
Next one I'm going to change out is the oil filter pan seal (short little strip).
If this don't work anyone got a suggestions? Friends at work told me to
try the the old mechanics trick & used one shot of Dot 3 brake fluid to
go into the seal & supposely the chemical reactions will expand the bad seal
& make it good temporarily until i'm ready to do some serious overhauling.
Any advice, suggestions, & tips is appreciated.
EG-SIXV-TEC
Feb 25, 2010 06:11 PM
dwn2earth922
May 3, 2007 08:30 PM
SamC
Apr 11, 2006 01:21 PM
RCautoworks
Jan 4, 2003 01:11 PM
keebler65
Aug 31, 2002 09:40 PM
