just installed coilover and then i lost steering
Old Mar 6, 2009 | 06:33 PM
blackhbkid's Avatar
Default just installed coilover and then i lost steering
Ok so i just installed skunk2 shocks, coils, and both front and rear camber kit. After installing i backed out of my driveway and i noticed the steering wheel was no longer straight "acura symbol was no longer horizontal" and the car did fine if i steered slowly, then i turned the wheel a few times in opposite directions and the car didnt turn at all. I waited tell the next street and tried to turn right "turning the steering wheel fast and i just continued to go straight. The wheels i have are balanced, i have the skunk2 shocks, coils, front and rear camber kit, front and rear sway bars and all strut bars. The car is a 95 Gsr
Old Mar 6, 2009 | 07:45 PM
j_bizach's Avatar
Default Re: just installed coilover and then i lost steering
something in ur steering is ****ed up id imagn ur tie rods id try installing ur stock springs again and see if that fixes it. Like the saying goes " if add something and something goes wrong then ther in lays the problem"
Old Mar 7, 2009 | 08:34 AM
whitengolddc2's Avatar
recheck your work.
Old Mar 7, 2009 | 10:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Did you disconnect your tie rods and forget to put them back??? I don't see why you would have just for installing suspension, though.
Old Mar 8, 2009 | 03:20 PM
95exvtech's Avatar
you might need a front end alignment
deerman2701
Aug 31, 2013 07:28 PM
baca00ex
20
Oct 19, 2010 06:43 PM
DcLs
Mar 4, 2009 11:50 AM
Lan
Suspension & Brakes
Jul 5, 2005 08:22 AM
1hotintegra
Mar 17, 2003 11:27 AM
