GSR in my CRX; help w/ Motor Mounts
Old Mar 6, 2009 | 04:22 PM
CRX_Honda's Avatar
Default GSR in my CRX; help w/ Motor Mounts
Basically a GSR motor is going into my CRX. I want Hasport Motor mounts. Will the mounts really run me like $500 or more in mounts because of the Hydro tranny?
Old Mar 6, 2009 | 04:57 PM
allgo88's Avatar
Default Re: GSR in my CRX; help w/ Motor Mounts
their are other mount kits that offer the hydro conversion.you get what you pay for.
Old Mar 6, 2009 | 06:47 PM
powerpro_69's Avatar
http://www.innovativemounts.com/
Old Mar 10, 2009 | 06:01 PM
streetsold6teeny8's Avatar
im doing the exact same set up as you... i got a gsr... u can buy the motor mounts seperate (make sure it is the kit with the hydro mount) and the hydro conversion seperate as well or together... which will run around what you said..
Old Mar 10, 2009 | 06:06 PM
protegehonda21's Avatar
yo hit up this website do it right the first time
http://images.google.com/imgres?imgu...%3Den%26sa%3DN
Old Mar 10, 2009 | 06:08 PM
S2Integra's Avatar
I believe Avid racing has your application.
www.avidracing.com
And yes $400-$500 is probably what you'll spend
Old Mar 11, 2009 | 05:06 AM
b16a1eg6's Avatar
Not only will you need the HAsport kit but you will need DA brackets to make it work.
http://hasport.com/tech/installs/EFB2.pdf
left-hand engine bracket 11910-PR3-010
rear engine bracket 50827-SK7-020
kobeballer96
Oct 9, 2009 02:30 AM
crazyboy
Jul 17, 2009 02:20 PM
SD1222
Feb 16, 2005 12:32 PM
dcviperboy
Sep 23, 2003 08:18 AM
russian_racer
Sep 19, 2002 08:53 PM
