Brakemotive -- Spring Kinetic Rotor Sale!!!!!
The weather is getting warmer and it's time to take those cars out of the garage! Spring officially starts on the 20th however we here at Brakemotive are starting our spring sale early! The following prices are good from now until the end of the Spring season. Prices are general to the type of car, please advise me of your exact year and trim level when ordering. Please PM me or give me a call at 708-704-2223 for info or to place an order. All Kinetic rotors are drilled and slotted and zinc washed for corrosion resistance. All items are in stock and will ship 24-48 hours form the time of order. Shipping is free in the lower 48 states. If your car is not listed PM me I most likely have it!
Accord
Front Rotors: $70
Rear Rotors: $70
Civic
Front Rotors: $70
Rear Rotors: $70
DelSol
Front Rotors: $70
Rear Rotors: $70
CRX
Front Rotors: $65
Rear Rotors: $65
S2000
Front Rotors: $70
Rear Rotors: $70
RSX
Front Rotors: $75
Rear Rotors: $75
RSX Type S
Front Rotors: $80
Rear Rotors: $80
Integra
Front Rotors: $70
Rear Rotors: $70
Integra Type R
Front Rotors: $80
Rear Rotors: $80
TSX
Front Rotors: $70
Rear Rotors: $70
TL
Front Rotors: $75
Rear Rotors: $75
CL
Front Rotors: $70
Rear Rotors: $70
Fit
Front Rotors: $65
MDX
Front Rotors: $70
Rear Rotors: $70
Evolution Ceramic Brake Pads -- Any Car
$30 per set (Front or Rear) or $60 per car (Front and Rear)
Accord
Front Rotors: $70
Rear Rotors: $70
Civic
Front Rotors: $70
Rear Rotors: $70
DelSol
Front Rotors: $70
Rear Rotors: $70
CRX
Front Rotors: $65
Rear Rotors: $65
S2000
Front Rotors: $70
Rear Rotors: $70
RSX
Front Rotors: $75
Rear Rotors: $75
RSX Type S
Front Rotors: $80
Rear Rotors: $80
Integra
Front Rotors: $70
Rear Rotors: $70
Integra Type R
Front Rotors: $80
Rear Rotors: $80
TSX
Front Rotors: $70
Rear Rotors: $70
TL
Front Rotors: $75
Rear Rotors: $75
CL
Front Rotors: $70
Rear Rotors: $70
Fit
Front Rotors: $65
MDX
Front Rotors: $70
Rear Rotors: $70
Kinetic is our house brand, they are only OEM replacement available in drilled and slotted only. I will see about getting some pricing on blanks.
We do not have a showroom no as we are just a warehouse, however our Kinetic Rotors are made in house you are more than welcome to stop by and see the process and take a look at the pars if you would like.
just find it interesting about civic rear rotors considering they have drums..unless its for Si and then, what bolt pattern are the civic rear rotors? I might be swapping GSR brakes into the back and need some rotors
I have all variations of the Civic available up to the current body style, just tell me what you need and i have them.
The service was good at the start but it seems after they get your money they don't seem to care. Don't expect to ever get your tracking number, i've asked 4 times now with three confirmed "i'll send your tracking info" and still nothing. I hope the product isn't like the service. Prove me wrong jim.
I've had those pads less than 120 miles. Broke them in properly per powerstop website. It's powerstop pads with kinetic rotors.
This is basically what's going on... i had ordered kinetic rotors/powerstop pad combo from you. the car drives straight and doesn't vibrate but then when i push on the brakes the car vibrates and shimmys and pulls right. At first the mechanic thought it was the pads so removed the front pads and replaced them with my old pads that still had 90% and the same thing happened. So we replaced the rear pads and the same thing happened. The rotors have discoloration and vibration marks from the pads i think that's what he called it and "S" curve marks or something. The pads have pieces missing from them or "gouge marks" don't think that's the technical term but that's what he called it. So far it seems that they are working with me on getting this resolved it could've just been a bad batch so i'll keep you guys updated on if i recommend them or not.
This is not a rotor issue, as i told you on the phone I think It seams like the pads failed, from the looks of them you can see where they look like parts crumbled away, my guess is they were dropped in shipping and formed a few small cracks that fell apart during use, The pad resin left on the rotor surface is due to the pad dragging, this also explains why the car pulls when you hit the brakes, one side is contacting the rotor first causing the pull. I still believer as I originally told you that the dragging pad has nothing to do with the cracking issue and is either a caliper problem or an install error on the mechanic's part. I also still stand by what i said about sending you replacements, as I told you i was willing to do. We have sold thousands of sets of these rotors and pads with no problems or failures. I will ship another set out tomorrow, when the warehouse opens back up. Please make 100% sure the break in is followed and please have the caliper inspected on the corner that was pulling as i am almost sure there is a problem there. I will be in touch with you tomorrow on this.
-Jim
-Jim
it's not the caliper, I had my original brakes that didn't do this and functioned properly. nor is it the installer as he's uninstalled and reinstalled them about 6 times. He's ASE Certified, OWNS his own shop and has been doing jobs on his own for about 30 years not counting what his family has been doing in the automotive industry. He's restored cars and has race cars that he works on. Not to mention he has not only seen the vehicle and the brakes but has driven it as well. Installing pads and rotors is pretty simple. He has told/showed me that there are vibration marks in the rotors from the pads that have caused surface marks on them. I have my old pads that have about 80% left in there and it's causing the same Vibration with the rotors i bought from you. He's gotten a chance to TOUCH and see the pads/rotors and DRIVE the vehicle. It's the pads and rotors that I BOUGHT from you. The mechanic and i both agree on that as well as other car enthusiasts. He even showed me how the color on the hub and rotor have discolored from using cheap materials. I'll take it to another shop and pay them to inspect it tomorrow.
Well i am willing to replace them as i said, however the 'discoloration' is likely due to the zinc plating coming off on the contact surface vs the plating that remains on the hub and edge of the rotor. If you would like replacements I can send them to you, I assure you we have not had an issue like this before with the kinetic product line.
Hi Jim, i took it to another shop today they said that it looks fine but if it's doing the same thing with my old pads as it did with pads i got from you it has to be the rotors as well. They agree with the previous person and said that i should get all new rotors and pads as everything was installed correctly. Is there a way i can upgrade to the powerstop rotors and powerstop pads, i believe the difference was like $50
