Honda S2000 Honda S2000
500whp or Bust (Picture Intense) 05 S2K w/30r
Old Mar 6, 2009 | 07:17 AM
ExVtec's Avatar
Default 500whp or Bust (Picture Intense) 05 S2K w/30r
I've had this on a few local sites for some time, but have never made it over here yet. I figured I will share, as I see alot of build threads creeping up over the past few weeks.
My goals are somewhere in the 400whp range on pump, and then a little over 500 on 110.
05 S2K w/a completely stock motor/head.
To do this, I'll enlist the help of these parts.
Tial 44mm vband w/g w/black housing on .5bar (7.25psi)
Tial 50mm bov w/alum mounting flange black housing on 11psi spring
GT3076R Turbo + jet coating hot housing
Pfab, EL Top Mount Manifold
Manifold Gasket
Comp Stage 4 Clutch
1000cc Bosche Injectors
Walbro 255lph HP pump
Liquid Filled Fuel Pressure Gauge
AEM EMS
AEM UEGO
AEM Serial Guage
AEM Boost Solenoid
3bar Map Sensor
Modifry's ECT fix.
Precision I/C
NGK BKR8EIK
Couplers
T-Bolts
3” exhaust piping
4bolt Flange
Mufflers x 2
Resonator
3.0” Alum I/C Pipe
A-Pod
Tuning (SlowMo)
Oil Feed -3an
Turbo Restrictor
Oil Return
Oil Return fitting
Sandwhich Adapter
[S}Coolant Feed & Return[/S]
Misc. metal for catch can setup.
Fittings & line for catch can
Battery Reloc. 2ga.
Battery
Magnetic Oil Drain Plug
A/C Relocation Lines
Marked off is what I have bought already.
[edit]
This was copy pasted, and evidently they don't have striket hrough installed here.
Old Mar 6, 2009 | 07:18 AM
ExVtec's Avatar
Default Re: 500whp or Bust (Picture Intense) 05 S2K w/30r
Some pics to occupy your time.
Mounted the cooler.
gt3076r w/a .82 exhaust housing.
The turbine housing got sent off a few weeks back to be jet coated black.
Fender off, to do a wire/ac tuck and to keep it from getting damaged while I work on it.
More to come.
ExVtec's Avatar
Pics of clutch.
Competition Clutch Stage 4.
Old Mar 6, 2009 | 07:19 AM
ExVtec's Avatar
Pics as promised.
Aem Serial Gauge.
Gauge in the apod (rough fit)
Aem EMS
ExVtec's Avatar
Here is some wiring I am working on.
I am relocating the battery/fuse box/abs computer.
I plan on putting my catch can there.
Old Mar 6, 2009 | 07:20 AM
ExVtec's Avatar
Pics are up.
t3 top mount manifold w/44mm vband Tial gate & 50mm Tial -Q bov
Enjoy.
Old Mar 6, 2009 | 07:21 AM
ExVtec's Avatar
I pulled the oem exhaust out. The pics were taken in the dark, so I had to use a flash which tends to wash the image out, however the exhaust looks to be in awesome shape..
I'm betting some sort of stainless steel.
It also weighs 100 million lbs.
OEM twinloop..lol.
Some sort of 90 degree silencer thingy?? JDM?
ExVtec's Avatar
Also pulled the header today as well. Crazy, this thing is also stainless, and looks very nice indeed. I see now why buying a header doesn't really add any power.
Old Mar 6, 2009 | 07:22 AM
ExVtec's Avatar
Also, I officially mounted the aem guage on teh apillar last week, and didn't post a pic.
Here ya go, it's wired, I just don't have the aem ems in the car yet.
ExVtec's Avatar
I finally got the tranny down and out.
To give you an idea of what all is involved, (if anyone cares, here is the link).
http://forums.s2kca.com/showthread.php?t=14201
It's certainly not your 45min bseries tranny..lol.
I started this adventure on Sat (sorta). Real serious on Sunday afternoon and little bit last night.
Pics.
I certainly couldn't have done this task w/o these...HIGHLY recommonded for your day/day duties.
I bought the set @ HF for $26 bucks, and these are for an impact so somewhat heavier duty even if they are HF quality.
Sent the flywheel off to be resurfaced.
ExVtec's Avatar
It's certainly worn, with plenty of hotspots.
48k miles.
Old Mar 6, 2009 | 07:23 AM
ExVtec's Avatar
Picked up the flywheel from the machine shop.
Ready to drop in this weekend.
I put this thing on the scale...21lbs.
ExVtec's Avatar
Here is the turbo after it was disassembled and I sent the housing off to be coated.
A picture with my cellphone to show the size comparison.
A picture of the exhaust housing after it was returned.
Full assembled but not clocked yet.
Final picture is of the 3" steel piping for the exhaust, the flex pipe, resonator and some misc fittings along with my sandwhich adapter and 2.5" alum piping.
ExVtec's Avatar
Pics might be far and few between until I get some actual work done.
Here is a small tease to hold you over though.
Old Mar 6, 2009 | 08:59 AM
JusAnother1's Avatar
looks good
Old Mar 6, 2009 | 09:30 AM
Black S2K's Avatar
cant wait to c it finished
Old Mar 6, 2009 | 09:46 AM
S2KFTW's Avatar
black coating the turbine housing looks great! my setup include one of those blanket things or else I'd do the same thing.
Old Mar 6, 2009 | 09:52 AM
jksmith's Avatar
sick build, but ROTA's , those are for poor people like me
Old Mar 6, 2009 | 09:55 AM
champwhiteeg8's Avatar
Wow very nice build
Old Mar 6, 2009 | 09:56 AM
96accordsir's Avatar
damn this **** is gonna be sick. ill be keepin my eye on this thread for sure.
Old Mar 6, 2009 | 11:14 AM
S2KFTW's Avatar
ha ha, I didn't even notice that, I was too busy looking at the shiny go-fast parts
Old Mar 6, 2009 | 11:29 AM
njebudalla's Avatar
rotas are easy to swap out. This guys got the important parts prioritized.
Old Mar 6, 2009 | 12:24 PM
ExVtec's Avatar
Thank you.
It came with Ap2 v1 wheels, that I sold to my buddy.
I used that money to buy those rims/tires. End the end, cost me 50 bucks.
I wasn't about to spend thousands of dollars on rims, when those do just fine and I like them.
I had other important mods in mind...
Old Mar 6, 2009 | 12:56 PM
njebudalla's Avatar
see, that is what i'm talking about... put the money where it counts. I dig that. Getting caught up in the flash can make you... not fast.
Old Mar 6, 2009 | 12:58 PM
njebudalla's Avatar
oh, btw, do you have e85 around your location? if you do, you might want to consider running that... well, you probably already have... but you can get great power out of that stuff.
