striped valve cover bolts on b18b1
Old Mar 5, 2009 | 03:31 PM
googoodc's Avatar
Default striped valve cover bolts on b18b1
ok, so i found oil in my spark plug hole and im figuring it is the little gaskets between the valve cover and the head, but anyway i tried to unbolt the bolts and 3 of them kept spining and spining can any help out and knows were i can new studs for it and how to put them in, thanks
Old Mar 5, 2009 | 03:37 PM
HONDRETTI's Avatar
Default Re: striped valve cover bolts on b18b1
i have trouble believing the threads are actually stripped on the bolts themselves, those nuts are notorious for stripped threading. order new ones from acura, and i would carefully use vice grips using upward force to remove the stripped nuts. ive had to do it once myself.
Old Mar 5, 2009 | 03:41 PM
googoodc's Avatar
sweet thanks so much,by any chance is acura the only place that sells them?
Old Mar 5, 2009 | 04:03 PM
tilegend's Avatar
they're either part # 18 or 19 depending on the location of the bolt.
its hard to tell from the picture but they have a hex head towards the bottom of the stud and you can actually use a deep socket to take them out
Old Mar 5, 2009 | 09:10 PM
googoodc's Avatar
thanks
Old Mar 8, 2009 | 12:33 PM
IMnobody621's Avatar
Ugh they do strip a lot, i HATE THEM lol! GL bro
Old Mar 8, 2009 | 02:34 PM
googoodc's Avatar
thanks bra
Old May 30, 2009 | 08:03 AM
reysdc2's Avatar
Originally Posted by googoodc
thanks bra
did you ever find those bolts?? if u did please tell me where u bought them thanks in advance!!!
PatrickGSR94
Nov 15, 2008 05:40 PM
DarkDragon
May 25, 2005 07:34 PM
Type_Rydah
Dec 23, 2003 06:20 AM
crxaddikt
Sep 19, 2002 10:08 PM
MrSmith
Jul 21, 2001 02:33 AM
