Caint find the right timing belt! HELP!
I am doing a build on a d16a6 block and putting a d16y8 head on it but i am running into to a prob with the timing belt. I tried the timing belt for the a6 and it is to big and i tried the timing belt for the y8 but its to small. What do i do please help!
I had problems with a belt about a week ago. I used aftermarket head studs and torqued them to honda specs. check spec for your studs and make sure they're good to go. Other than that try what Jas9848 said see if any of that helps you.
corey198807
Oct 13, 2010 12:27 PM
