OKay.. Its so close to being done. Now doesnt want to start right away every time????
Old Mar 5, 2009 | 09:59 AM
JoshJosephKeith's Avatar
Default OKay.. Its so close to being done. Now doesnt want to start right away every time????
Car doesnt want to start right away. I can start it it will start right away then next time take a couple cranks then start.. AND the rpm gauge will work, but then it dies every now and then like it doesnt want to work. I just put a different disty on.. and I had to wire the Ignitor wire from my hf harness driver side connector to the disty i havent soldered them yet but they are pretty tight connections im positive. Should I swap distys with my old one? Because I know that one is good now, I just thought i had a disty problem because of me having an hf chassis harness and si engine harness and the ignitor wires not matching up so it would pull a code 15 thats why i changed them.. but that wasnt the problem.. Id appreciate the help thanks guys
ALSO .. my heat doesnt want to turn on right away.. if that has anything to do with anything??
08yfzrider
Aug 4, 2010 06:06 AM
Otownking10
22
Apr 25, 2010 05:27 PM
R015
Apr 23, 2009 06:19 PM
kittylizzy22
Mar 10, 2007 09:28 AM
C-REX 88
Aug 8, 2004 07:19 PM
