I used 10w30 oil on my da b18a1,bad?or not so bad?
Old Mar 5, 2009 | 01:58 AM
JASIYAH6's Avatar
Default I used 10w30 oil on my da b18a1,bad?or not so bad?
Yea i didnt have my manual on me so went to the auto store and the genius sed use 10 w 30 but i changed the oil and i noticed later it was 5w 30.what do you think?
Old Mar 5, 2009 | 02:09 AM
GsDAteg's Avatar
Default Re: I used 10w30 oil on my da b18a1,bad?or not so bad?
Doesn't matter. 10w30 is just a little thicker when cold, otherwise it's the same stuff.
Old Mar 5, 2009 | 03:40 AM
delbert's Avatar
don't matter really, i used valvoline synthetic 10w-30 in my gsr
Old Mar 5, 2009 | 06:29 AM
JASIYAH6's Avatar
yea i figured its just a lil colder in startup
Old Mar 5, 2009 | 06:47 AM
94_Teggy's Avatar
your golden....dont worry bout it
Old Mar 5, 2009 | 06:51 AM
jr92hatch's Avatar
dont trip man
i use 10w30 in my 95 gsr
Old Mar 5, 2009 | 09:31 AM
super jdm yo's Avatar
no difference, but for vtec they say to use 10w30 other than that 5w30. although like said earlier they're practically the same. unless you have a hybrid that's 0w20
Old Mar 5, 2009 | 01:58 PM
twentyhurtz's Avatar
castrol 10-30, have used it in all my honda's..
Old Mar 5, 2009 | 02:17 PM
nsxtasy's Avatar
H-T Order of Merit
If you're referring to Acura as "they", then this statement is NOT true. The owner's manual and service manual recommend 5W30 as the preferred viscosity for all Integras (including the VTEC models) at all temperatures. They say you can also use 10W30 as long as the outside temperature is above 18 degrees F, but 5W30 is still preferred.
Old Mar 5, 2009 | 02:22 PM
bunnyhatch93's Avatar
5W30 is recommended in the owners manuals by 10w30 is cool,.
Old Mar 5, 2009 | 02:28 PM
kulo's Avatar
5w30
Old Mar 5, 2009 | 02:36 PM
honda pride's Avatar
Either or 5 30 is better for summer cuz its lighter
Old Mar 5, 2009 | 02:45 PM
ALLxMOTOR EG's Avatar
Vietnamese!
you'll be ok.
Old Mar 5, 2009 | 03:46 PM
racebum's Avatar
the 5 and 10 are cold flow numbers. i can't remember what temp the rating is done at but both are 30w at operating temp. some of the better synthetic 10-30s will outflow a dino oil 5-30w according to the print. i use redline 10-30 on my R motor. it also helps that i pay $5 a quart for it
Old Mar 5, 2009 | 04:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
5w30 and 10w30 is the SAME viscosity at operating temperature. If your engine leaks oil, it will leak oil just the same with either weight when the engine is hot. Using 10w30 to reduce engine leaks is really just a myth, unless you ONLY drive your car while the engine is cold and NEVER let it completely get up to operating temperature. If that's the case, get ready to rebuild the engine soon.
I use 5w30 year round in my 275K mile GS-R for one main reason: less wear during cold startup. Over 80% of engine wear occurs during cold startup before the oil gets up to full operating temperature. So really, there isn't really much of a point in using 10w30 IMHO.
Old Mar 5, 2009 | 04:40 PM
OOOtony's Avatar
5w30 is recommended for motors under 70k miles 10w30 would be good for motors over the 70k.
if it says 5w30 on manual
Old Mar 5, 2009 | 04:51 PM
Community Builder
Recommended by whom? I just checked the level of 5w30 in my 275K GS-R, and after about 3500 miles since my last oil change, the oil level is about 1mm below the upper hole on the dipstick.
If you want to keep engine wear to a minimum, use 5w30 or hell, use 0w30. The oil with the thinnest cold viscosity that has the correct hot viscosity (30w in our case) is best. I haven't seen much 0w30 oil in my area, so I use 5w30 Valvoline MaxLife synthetic blend.
Old Mar 5, 2009 | 05:05 PM
TenaciousB18c1's Avatar
Post a link to that write up that the doc did. If they truly care about whats going on with their oil, they'll read it.
Old Mar 5, 2009 | 05:19 PM
Community Builder
Original Motor Oil 101 by Dr. Haas on Ferrari Chat:
http://www.ferrarichat.com/forum/sho...d.php?t=136052
Other articles by Dr. Haas (the above one included):
http://www.ferrarichat.com/forum/faq...=haas_articles
accord99power
May 7, 2009 09:40 PM
int96gsr
Apr 29, 2009 09:24 PM
crazyguy
18
Aug 1, 2008 04:46 PM
bobmugen
Mar 11, 2008 07:45 AM
Riga89
Nov 17, 2007 04:38 AM
