ls into sedan
just need a quick answer do i need to pound the cross member and under the driver strut tower to fit a ls in the sedan? i know its true for the b16 into crx n watnot didnt know if there was a difference and ive searched it kinda but nothin came up that was straight forward enough
what header will allow to fit im not dumpin the car but its definately lowered, i will have 15" slipstreams with 45-50 series tires and its on ebay coilovers that are down to the ground any ideas on a good header for clearence? and i plan on makin a cover plate for it to keep it from gettin trashed on scrapage
I know this is a nub question but wtf is a d-series alt like alternator? and just to double check i need teg axles i have the int. shaft and linkage i need to cut to fit, i need throttle cable and clutch cable?
Any other input on wat i will need to pick up im getting just the motor/tranny from a friend i have the engine harness too
i got a 97ls in my ef hatch, it has a 4-1.. but for the 4-1 to fit, the crossmember was notched out a prettty good amount.. and the ls is bigger than a b16 so its even closer to the bulkhead, def needs to be "beaten"..
O reary? Pretty sure they are the same size there guy.
The block IS taller tho. It's the reason b16a headers will usually touch a b18's oilpan.
ever notice that b18 headers are different part numbers from the b16a versions?
It's like that for a reason
