em2 on GROUND CONTROLS
Some searching would yield you the feedback you're looking for.
https://honda-tech.com/search.php
im on gc sleeves w/ stock shocks **blown shocks ftl
i still have to save up for shocks and rear camber kit. i plan on running tokico dspecs. but for
right now the ride doesn't bug me. a bit bounce that's it.
I haven't heard any feedback on the Dspec/GC combo, though.
. The koni's requre hacking your stock struts, draining your old strut, and machining out the cylinder. The strut inserts cost koni less to make, but take a lot more modification to make work. Read this article then tell me it isn't hard to do.
http://www.hondatuningmagazine.com/t...ion/index.html
I run dspec/gc, they're perfect
. The koni's requre hacking your stock struts, draining your shock old and machining out the cylinder. The strut inserts cost koni less to make, but take a lot more modification to make work.
. The koni's requre hacking your stock struts, draining your shock old and machining out the cylinder. The strut inserts cost koni less to make, but take a lot more modification to make work. Read this article then tell me it isn't hard to do.
Ive done it 3 times. its really not that hard! and there arent too many coilovers better than this koni setup im running. especially not within the same price range. have you done it btw?
no I haven't, no need to. If they were the only clear best choice then I would have started drilling, but they are no better than Tokico D-Spec's and that's a fact. For our cars they are a good option but not the best. If I didn't go with Tokico I would have gone with Progress full coilovers. For wishbone suspension chassis (all civc's prior to ours) the koni yellow/gc combo is a superior choice.
thats bc most full coilovers are crap for this car. Konis arent really all that great either. 6 months and mine were thrashed and another member on here went through 3 sets before finally getting Tein SS's. After mine blew out, i went for Tein SS-P's. Its all luck of the draw though. I also know people who has had theirs on their cars for 3+ years without issues.
they make plenty of good coilovers for this chassis in the $1000-$1200 range some of you must be forgetting the rsx setups available. i jus cant see spending that much money for sleeves and strut inserts.
everyone is running different applications for their car. some one wants to ride slammed, while a guy over here wants to be competitive in sts. no setup is going to be so versatile that they can shine in every application the user applies them to. thats just how most companies market their coilovers so they can sell. everyone has different opinions and different needs. what defines a "good" coilover setup?? b/c it doesnt fall apart? b/c it has perfect dampening for the autox course you ran last weekend? b/c you can tuck tire with it?
get what i'm trying to say?
decide what you want to do with your car. research about it, then research components. and dont count the "tein ftw" as valid results (no offense to you D17alltheway) b/c they dont imply any valid feedback about any component.
and op, many ppl are running different spring rates, heights, and dampers with the ground control setup. if your referring to the sleeve and lock collar itself, id say they are very good quality materials
