WTB: ITR Rear Brake Calipers
Can anyone confirm this. I tried to match the part numbers, but Acura doesn't give you the part number for the bracket and the caliper seperately for the ITR. They just say you have to buy the bracket and caliper together for both models.
from the research i've done is that the rsx/ep3/itr rear calipers with brackets are all the same. the calipers on all integras in the rear should be the same as the rsx/itr/ep3, just the brackets are different to compensate for the different hub/rotor offsets.
