crx dash into hatchback
Old Mar 4, 2009 | 06:22 PM
kyle2436's Avatar
Default crx dash into hatchback
will a crx dash fit in my 91 honda civic hatchback without cuttin or changing any braceing or what not what all will be needed for the swap?
Old Mar 4, 2009 | 06:53 PM
xileap2's Avatar
Default Re: crx dash into hatchback
its not a straight swap
Old Mar 4, 2009 | 07:08 PM
pandarex's Avatar
its pretty much a straight forward swap. i had to change up some wiring, but if you have any mechanical skill you should be good.
Old Mar 4, 2009 | 09:18 PM
KoDKingVegeta's Avatar
For the most part its a direct fit. You need to change a few of the brackets on the floor so the new center console part bolts up right. But other then that, it fits right in. Took me about an hour to pull the old dash out (I had to completely unbolt my steering column and drop it, so the old dash would come out, and the new one would go in. But its a piece of cake. Just dont rush it.
And whoever tells you, you need to take the CRX heater controls out is wrong, the stock ones bolt right up. You just have to carefully tuck the heater wires out of the way, other wise your CD player will make it so, that you can change from the blower to the defrost.
Also, you will need to take the wiring harness out of your dash, and stick it into the CRX dash, just unscrew a few screws, and thats it.
Mr.Cheezil
Sep 18, 2011 07:50 AM
thedudefromjerz
22
Jun 20, 2011 08:39 AM
ERKK
14
Jul 18, 2009 07:13 AM
lilredcivic
Sep 25, 2005 07:55 PM
drunk
Aug 4, 2002 07:27 PM
