Heater fan
Old Mar 4, 2009 | 11:06 AM
endless22's Avatar
Default Heater fan
theres a fan behind my glove compartment thats makes the heater work i know this because i have to bang on with a srew driver to get it to work.. And when it does it makes a loud ticking sound does anypne know if i can rebuild this or how to replace it i think i would have to take the hole dash out its a 93 accord lx.. Any help or pics would be nice thanks
Old Mar 4, 2009 | 03:42 PM
AccordEX1991's Avatar
Default Re: Heater fan
You can pull out the blower without pulling the whole dash. You only need to take out the glove box and you can see and pull it out by undoing some 10mm hex bolts and one clamp holding the blower assembly to the evaporator coil section.
Old Mar 4, 2009 | 05:59 PM
91wagon-ex-r's Avatar
New User
It sounds like you might have a stick or leaf in there.
Of all the vehicles I've owned, this is one of the easiest. Last week on my 91 wagon I replaced my heater blower with amazing ease.
The shop near me quoted 1.8 hours @$110 per hour, that's just for the re & re of the heater.
And because I mentioned I have A/C add another 1.2 for a total of 3 hours @$110.
The only tricky part is releasing the electrical connectors.
The only tools you'll need are,10mm deep socket, short extension, ratchet, and a properly sized Phillips screw driver.
If you want complete instructions drop my a note and I'll word straight out of the manual.
Last edited by 91wagon-ex-r; Mar 4, 2009 at 06:01 PM. Reason: for to address original complaint.
Old Oct 20, 2009 | 01:49 PM
91ex's Avatar
I have this very same problem. My motor was acting funny for a long time making wierd noises so I figure its probably that. I was having to slap under the glove box to get it to work as well. My question is, I cant seem to get the cover out from underneath the dash. its pinned and wont slide down or in either direction but 1". Is there a secret to getting the thing in half? I see a white piece on the right upper side with screws in it but I cannot get to it. Am I doing something wrong?
Old Oct 20, 2009 | 02:00 PM
endless22's Avatar
well i took mine out which aint easy. first you have to take out 2 bolts on the side of the dash and remove the glove compartment. then take out the bolts holding the heater box on so what it is is a big black box with a fan in it. i cleaned it and put it back in and it still makes the ticking sound and you have to touch the fan to get it going. so i am just going to replace the whole dam box.. not unless i could figure out how to rebuild the motor. which it probaly would be a waste of time
Old Oct 20, 2009 | 02:18 PM
91ex's Avatar
2 dash bolts hidden by the door on the side of the dash?
Old Oct 20, 2009 | 02:28 PM
endless22's Avatar
yea thats right but if its doing the same in mine theres no use to take it out.. not unless you are going to replace t
Old Oct 20, 2009 | 02:38 PM
91ex's Avatar
Yea I'm gunna atempt a fix or replace it. It has completely stopped working at this point so I have no heat. I'm starting here because that noise drives me crazy. It has power and everything so im sure its bad. Hopefully thats all thats gone wrong. I appreciate the advice man i was gunna loosen the dash but I thought that wouldn't help after looking at it. I'll get back out there and let you know what happens.
Old Oct 20, 2009 | 05:49 PM
91ex's Avatar
Tried loosening the bolts but it still won't come out. Im thinkin Im gunna break somethin if I keep pullin and forcein. Was it the same for you?
Old Oct 20, 2009 | 09:38 PM
endless22's Avatar
yes just make sure all the bolts are loose. i think there was 3 bolts holding the whole thing on. its lookes like more but theres not. and the bolt on the metal bracket which is tricky to get back on. but once everthing is loose just pull on it and pull your dash back as far as it will go . i actually heard my dash crack. in a spot but no worrys its fine. and just pul the whole box out. and thats it ..just remember how everything fits back in .also theres 3 plugs on it take a flat head screwdriver and unplug them
tehondafrk
18
Dec 8, 2012 10:16 AM
msnewman
Feb 1, 2010 04:56 PM
efyou
Mar 12, 2007 01:10 PM
Chris Sawatsky
Nov 2, 2004 07:44 AM
Batchs
Sep 13, 2004 05:28 PM
