injectors not grounding????
Old Mar 4, 2009 | 06:09 AM
98GSR-Turbo's Avatar
Default injectors not grounding????
well i put a ls/vtec in my 96 ex and the injectors arent grounding. i put some dsm 450s in with inline resistors 10 watt 10 ohm. they are getting power but there not grounding out. what is the problem?
Old Mar 4, 2009 | 06:11 AM
mikesrex's Avatar
Default Re: injectors not grounding????
the ground is actually the signal that the ECU sends to the injector for it to fire. it will always have a +12V signal. How are you trying to measure the ground signal?
Old Mar 4, 2009 | 07:01 AM
there is no signal/ground from the ecu. i put a test light on the pos on the battery and had someone try to start it and the light didnt even flicker.
VTEC_1229
Jul 29, 2016 11:44 AM
anon191
17
Jun 25, 2013 10:33 AM
EGcivic_95
Feb 28, 2012 05:42 PM
Käras
16
May 10, 2011 07:23 AM
civbeater90
Nov 23, 2002 09:37 PM
