help with tire and wheel combos
im bulding my first import drag car mostly bracket and some heads up
its a 94 integra gsr
looking for 400-450 hp
i need help getting the right tires and wheels with the right amount of backspacing to clear the brakes thank you
at least a 4" backspace. The usualy backspace is 4-5".
I'm assuming youre on a stock GSR trans/gear set. and RPMs up to 9K.
If you are really making a solid mid 400s, the 24.5" tall tire would be best for you. something like an M&H 24.5x8.5
If youre making peak power in the low 400s, but most of your powerband is in the 300s, i'd stick with a 23x8x13.
https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/wow-drag-slicks-wheels-exospeed-racing-wheels-m-h-slicks-m-t-combos-aka-lenso-2504027/
Check out our link to see the different choices you have for tire sizes and pricing.
