turbo or super or n/a
i just put my b18c1 in and am trying to decide what im gonna do before i go buy a bunch of add ons.i dont have a problem saving up for a turbo i just want to make sure the car will still be very dependablethe car is mostly for daily driving and the track sometimes.id like to be at 200 to 225 whp.that be great and get there at the best price and and still completely dependable
My friends turgo gsr puts down 251 with 7psi. He gets 30mpg. By not boosting everywhere you go, you can use the turbo help the efficiency of the engine. With the turbo my friend is able to get 0 vaccum at 1/4 throttle. With little load, no boost, and 0 vaccum the engine is breathing very well. Best of all, if you want *** whooping power its there, at the price of fuel economy. Its totally streetable.
Turbo's actually help clean emissions with the right fuel setup. A greddy turbo kit cleans emmisions down to a third of stock.
A high compression all motor car can end up with higher cylinder pressures than a lower compression turbo car producing twice the power. Reliability is affected by many things and one is cylinder pressure.
From: Toronto, Canada currently residing in ATL, GA, USA
For reliability nothing but stock to be absolutely safe.
That being said if you want power and you aren't afraid of tearing something up then look @ it like this.
Turbo for power
S/C for a bolt on solution cost effective solution
N/A for something that is more challenging and rewarding @ the same time.
They cost alot done the right way. Turbo costs the most but you get more power gains from it. S/C to me is a waste of time when you can get almost the same power from a N/A car.
Turbo for power
ok well all this helps .i was always thinking of getting a turbo,but i got a jdm b18 and io am told that it has higher compression pistons.how much will that effect a turbo,and can some people tell me what kind of setups they got and what all i would need if i did go turbo.
