Can Anyone Help!!??
Old Mar 4, 2009 | 01:53 AM
EJ1 LS guy's Avatar
Default Can Anyone Help!!??
Man This was my last resort....But I Need 2 change my tires......So Here's My problem:
I Can't Get My Lug Nut off....
I Lost The key and nobody has a match for it....And I really need to get my tires changed like asap......so ANY help will do......remember ANY help will do.......thanx in advance
Old Mar 4, 2009 | 01:58 AM
Davus's Avatar
Default Re: Can Anyone Help!!??
Have you tried taking it to a place that specializes in wheels and tires? Some keep extra keys around, or would be able to remove it by force. If that fails, you may have to invest in some drill bits and try to force through the lock, at least enough to make a socket fit over it and turn it. Careful not to hit the stud. Angle grinder may work?
Also try parking in a ghetto, while on jackstands. This will cost a wheel, but will get it removed.
Try chiseling through the openings with a chisel and good hammer, carefully of course. Split the thing open basically.
Old Mar 4, 2009 | 02:08 AM
EJ1 LS guy's Avatar
Yeah..I have tried some close by shops..no luck....But thanx for the ideas....
anymore?
Old Mar 4, 2009 | 02:03 PM
EJ1 LS guy's Avatar
3:03
Old Mar 4, 2009 | 02:45 PM
94EG8's Avatar
Seagull Management
This is really kind of last resort type advice, but you can try welding a nut to the end of the locking nut. Note that its much harder to weld a nut to something like this then you would think. Large stud remover might work too, its a round nut.
Old Mar 4, 2009 | 03:06 PM
trustdestruction's Avatar
pretty sure that's an OEM honda locking lug... just get the key from honda
Old Mar 4, 2009 | 09:55 PM
EG TYPE-R's Avatar
just go to sears and buy extractor that is the right size. they make some that are made to do just that.
Old Mar 4, 2009 | 10:11 PM
thetunersource's Avatar
Damn man, you got to get an extractor set, consider getting a titanium set, and that will take care of it, but you gotta take a lot of time.
Nate047
Aug 14, 2004 07:13 PM
gh0st32
Jan 16, 2004 08:36 AM
JDM_ITR
Sep 11, 2002 09:12 AM
turboex
May 25, 2002 12:59 PM
d8168055
Mar 8, 2002 11:28 AM
