Wierd noise please help!
Well i'm getting a wierd thumping noise. It starts going around 40km/h and gets louder and faster the faster the car goes thump thump thump thump..... It doesnt change with engine rpm but only with speed. Checked the tire pressure and it was all around 32psi. Tires are almost new also. 195/50/15 falkens on sir rims.
What could it be? Sounds like its coming from the front, more like the front left.
Thanks alot
Thanks alot
Sounds like you may have a flat spot on your tire, either from rippin on your tires or just a chunk of tire that ripped off. i had new tires that just started missing chunks from one of the tires. it happens. hope this helps
could be many things, could be tires, or if its more of a click, could be axel or even loose brake caliper. could be lots of stuff, you just need to start checking each thing. GL
