starting problem on my 2000 si
Old Mar 3, 2009 | 05:54 PM
TruJDMEG6's Avatar
New User
Icon6 starting problem on my 2000 si
having trouble getting my so started! I've checked the battery and cables, I replaced the fuel filter it has a new fuel pump, I don't know what's going on! Anyone have any suggestions??
Old Mar 3, 2009 | 06:11 PM
sirtef9's Avatar
Default Re: starting problem on my 2000 si
Did you check for fuel or spark first?
Old Mar 3, 2009 | 06:14 PM
TruJDMEG6's Avatar
New User
I haven't checked the distributor, or sparkplug wires.
Old Mar 3, 2009 | 08:47 PM
llozll's Avatar
does it crank?
u hear pump spins?
Old Mar 4, 2009 | 05:21 AM
fcm's Avatar
fcm
Old Fart
Way more info needed.
Will engine not turn over, [crank]?
Will engine turn over but not start?
Will engine turn over and start but has trouble doing so?
You need to be clear on exactly what happens when you turn the ign. key to start.
When you turn the ign. key to run, [not start] can you hear the fuel pump prime the fuel system, [run for a few seconds then turn off]?
As mentioned, you need to check to see if you have spark and fuel. 94
Old Mar 4, 2009 | 04:48 PM
EK2.0's Avatar
right on! lol
kobe2324
Feb 8, 2015 01:14 PM
keemerdadreamer
Feb 11, 2010 04:26 PM
SsB_Db8
Apr 30, 2009 07:29 PM
No
Jan 26, 2005 01:51 PM
