b18 c1 swap trouble
put a 94 gsr in the ef and i ran into a problem the altanator pulley hit the frame of the car before it even get tight. my question is, is there a smaller belt or something that i could use?
you could try finding a smaller belt, and that sounds logical, however i've never seen someone suggest that before. with a b-series swap you have to bang out that area on your inner frame rail to make pulley clearance. i had to do this myself with the engine in the car because i didn't make enough clearance when i tried banging in that area the first time when i had the engine out. in order to get enough room to swing a hammer at the offending area i had to remove the alternator, alt bracket (if i recall), axle, and intermediate shaft.
b16_madman
Apr 26, 2005 08:19 PM
notfastenough
Sep 1, 2004 12:00 AM
DXDOHCVTEC
Sep 1, 2003 12:06 AM
