threaded holes in the rotors?
Old Mar 3, 2009 | 05:14 PM
gunterelectric226's Avatar
Default threaded holes in the rotors?
I can't for the life of me find the right bolt for the rotor. It is extremely stuck to the hub and I need the thread count for the holes provided to break a stuck rotor free from the hub. I have tried all the bolts I have on hand(mostly standard) and no luck. Anyone know what I am looking for?
Old Mar 3, 2009 | 05:18 PM
94EG8's Avatar
Seagull Management
Default Re: threaded holes in the rotors?
1.25 x 6mm if I remember correctly. Just hit the center of rotor with a hammer between the studs.
Old Mar 3, 2009 | 05:24 PM
I just put the kids to bed and was trying to get it off to finish diagnosing the steering/suspension issues in my wife's 97 civic. I have never had a problem getting the rotor off before. This time it is stuck bad. I have hit it several times with a rubber mallet(again with the noise and kids). I guess I will give it a few more shots. If I can't get it tonight I will get the 4lb hand sledge out tomorrow after work.
Thanks for the help.
Old Mar 3, 2009 | 05:29 PM
94EG8's Avatar
Seagull Management
You're wasting your time with the rubber mallet, just go at it tommorrow when you can make some noise with a good siezed ball pein hammer or a club hammer.
Old Mar 3, 2009 | 05:43 PM
I just tried a hard plastic hammer with a 20oz estwing and no success. I pretty much figured I wasn't going to accomplish anything but at least I tried. I appreciate the help. I am getting alot farther into my working on vehicles. Meaning I have never worked on the suspension and steering systems before(on a Honda[fwd]). I just rebuilt the front axle on my Bronco and now it is the civics turn. I am just going to go thru and find worn parts that need to be replaced. I will probably be asking more questions as I get into this. I will search everything before I ask as I know that can be the easiest answer for most questions.
Again I apreciate the help.
Jeff
Old Mar 3, 2009 | 06:13 PM
roadsqueegy95's Avatar
we replaced the brakes and rotors on my buddys car the other week, we had to smack it from behind with a sledge hammer, they were rusted on pretty damn bad!!
Old Mar 3, 2009 | 06:16 PM
KrazyLuEg8's Avatar
just drill the head of the screw..dnt kill ur slf
Old Mar 4, 2009 | 05:00 AM
94EG8's Avatar
Seagull Management
He's already got those screws out, theres a second set of threaded holes in the rotor itself, you thread bolts in them and the push against the hub behind forcing a stuck/rusted rotor off the hub. However most guys just hammer on the rotor.
Assassinxiv
Suspension & Brakes
Jan 9, 2013 06:27 AM
zbase
Jun 21, 2007 06:57 AM
92 CIVIC HATCH VX
Nov 2, 2005 07:16 PM
Hyb
11
Apr 2, 2005 08:14 AM
LOWLIFEHATCH
Sep 30, 2004 03:11 PM
