Head Gasket Thickness effecting Compression on H-series
Old Mar 3, 2009 | 01:22 PM
1SIKZ06's Avatar
Default Head Gasket Thickness effecting Compression on H-series
I know stock is right under .030...I think .026... Ho wmuch will the compression be lowered if i go with a cometic .060 or .080? My block was decked and my wiseco pistons are hitting the bottom of the head. Im debating whether to just go super thick and be safe or just get what i need and keep my quench nice and tight. But if the compression is not "TOO" different then id rather be safe. The Pistons have a huge dome so i have compression to spare
Old Mar 3, 2009 | 04:08 PM
GoldLudeRay's Avatar
Default Re: Head Gasket Thickness effecting Compression on H-series
you probally have the wrong pistons for set-up if there hitting the head
but there is a compression calculator for the h/f motors in the civic faq
but a ruf estimate is if stock pistons are 10.0.1 cr with a .026 headgasket a head gasket with a tickness of .060 would lower the cr too 9.5.1 thats an estimate,,, find the h series calculator in the civic faq
Old Mar 4, 2009 | 12:59 PM
1SIKZ06's Avatar
The machine sjhop over decked the block...thanks though
monster_c
Apr 5, 2012 09:53 AM
JAMSiR
May 26, 2010 08:24 AM
kc4door
Jan 22, 2006 05:47 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
allmotorgsrekk
Jan 17, 2004 11:18 PM
