Valve spring/Retainer question
Old Mar 3, 2009 | 12:43 PM
'94civic b16's Avatar
Default Valve spring/Retainer question
I have a stock b16 head and I bought some ITR cams that I would like to put in. Now I know I want to upgrade the valvetrain to accommodate the additional revs I am pursuing so I bought some supertech dual valvesprings for dirt cheap from a guy locally. Would it be ok to run the dual valvesprings with the ITR cams and stock retainers or are upgraded retainers a necessity? Thank you in advance.
Old Mar 3, 2009 | 09:14 PM
Default Re: Valve spring/Retainer question
Anyone have any insight or know where I could look to find out?
Old Mar 3, 2009 | 09:16 PM
lsvtecracer's Avatar
You should be fine with the stock retainers.
Steve
Old Mar 3, 2009 | 09:57 PM
Thanks Steve, not doubting your answer but a second opinion always helps, so anyone else?
Has anyone had any bad experiences running dual valvesprings without aftermarket retainers?
Old Mar 4, 2009 | 09:27 AM
anyone?
Old Mar 4, 2009 | 03:00 PM
mmuller's Avatar
Mad Scientist
if you have 1st gen b16 retainers, i would not.
Old Mar 4, 2009 | 08:15 PM
they are second gen b16a
Old Mar 5, 2009 | 01:22 PM
hmoobhero's Avatar
just get itr retainers...do it right the first time so it wont cost more later. plus, itr ratainers arent that much. theres a set of itr/ctr dual valve springs and retainers for 100 bucks for sell here.
Old Mar 5, 2009 | 03:04 PM
Oh what happened to yours when yours broke? Will take that into consideration.
Old Mar 5, 2009 | 04:06 PM
havok hybrid's Avatar
Get ti retainers at the least. 9k revs.. you want to have a peice of mind that everything is ok....
Simple install.. and cheap.
408EJ1
Mar 28, 2011 05:40 PM
LSVtechnologytur...
Jan 26, 2007 02:44 PM
JDAMC
Aug 6, 2006 04:56 PM
1badda
Apr 28, 2006 06:25 PM
