Will a lightened flywheel show hp on dyno
Old Mar 3, 2009 | 10:42 AM
b20beast83's Avatar
Default Will a lightened flywheel show hp on dyno
Will putting a lightened flywheel show up hp on the dyno?
Old Mar 3, 2009 | 10:52 AM
Dark_Teg's Avatar
Default Re: Will a lightened flywheel show hp on dyno
Yes it will, You are not adding HP with a lightened flywheel but you will free up some previously wasted HP.
Old Mar 3, 2009 | 12:00 PM
OmegaDynamics's Avatar
No, the only thing that will change is the RoA
Old Mar 3, 2009 | 12:24 PM
DonF's Avatar
An inertia type dyno might, but a real engine dyno will not.
Old Mar 3, 2009 | 12:35 PM
b20beast83's Avatar
inertia type is dynojet?
Old Mar 3, 2009 | 12:46 PM
689R's Avatar
No, this does not mean its not an excellent mod though.
Old Mar 3, 2009 | 09:12 PM
Scott_Tucker's Avatar
It will definitely make the car quicker in the same way lightening the car by removing the sound insulation would. There is less mass to spin up. But on a real dyno where you stabilize the engine speed at each RPM point for a moment while measuring the torque it will not show up. You will only see a gain when that mass is being accelerated, not when it is at a constant velocity. A dynojet is not a true dynomometer in that it does not use a brake to absorb power it instead calculates power based on how long it takes to spin up a certain amount of mass.
Old Mar 4, 2009 | 05:31 AM
Dark_Teg's Avatar
I picked up 6RWHP and 8RWTQ on a dynojet. I went from a 25 to a 14 lb flywheel.
This was on my 5.0 mustang. I changed the clutch as well so maybe the clutch was just holding better or something.
Old Mar 4, 2009 | 06:00 AM
mikesrex's Avatar
yes, it will to a small degree.
remember that when you spin a heavier flywheel up to speed, you are storing energy that you could otherwise use to accelerate the roller on the dyno.
Old Mar 4, 2009 | 07:22 AM
ddd4114's Avatar
Steady-state measurement = no gain
Transient measurement = gain
This is an example of how dyno measurements can be misinterpreted. As stated, the engine is not producing any more torque at any speed, but the its moment of inertia has decreased, so it will accelerate more quickly.
Old Mar 4, 2009 | 08:20 AM
Dark_Teg's Avatar
The more I think about it the more I dont see how it wouldnt show up. Anything that helps get more HP/TQ to the wheels would have to show up I would think.
Old Mar 4, 2009 | 08:24 AM
ddd4114's Avatar
"Getting more torque/power to the wheels" is sort of a vague statement. It could suggest that parasitic losses are reduced, frictional losses are reduced, or rotational inertia has decreased.
If the dyno is operating at steady-state, no energy is required to accelerate the flywheel, so there would be no difference in torque measurements after switching flywheel weight.
Old Mar 4, 2009 | 12:26 PM
Dark_Teg's Avatar
Are you talking about an engine or chasis dyno?
Old Mar 4, 2009 | 01:07 PM
DonF's Avatar
Either one if you do steady-state testing, not acceleration testing.
Old Mar 4, 2009 | 01:27 PM
Dark_Teg's Avatar
Well I learned something new today.
Thanks,
Old Mar 4, 2009 | 06:59 PM
00Red_SiR's Avatar
All Motor Mentor
As stated previously it's the same as running on a dynojet with 15" wheels and then bolting on some heavy 17" wheels. The dyno's I have personally seen showed a 4-5 whp loss on a b16a. The more weight you have to spin up, the more energy consumed, which shows up on a dynojet, not an engine dyno.
Old Mar 4, 2009 | 09:20 PM
It shows up on a Dynojet because it's an inertial dynomometer. It will show up on any brand of inertial dynomometer, but not on a brake type dyno. It doesn't matter if it's a chassis dyno or an engine dyno as long as it is a brake type dyno.
Old Mar 4, 2009 | 10:38 PM
mikesrex's Avatar
What? It still takes more energy to accelerate an object, regardless of its mass or speed.
you didn't answer the guy's question. nobody wants to hear some nonsense that doesn't relate to the original question! I'm pretty sure most of us have taken high school physics, so you guys don't have to flex your highschool physics knowledge to us here.
YES, YOU WILL GET A HIGHER POWER READING ON A DYNO WHEN YOU MAKE A DYNO PULL WITH A LIGHTENED FLYWHEEL.
Old Mar 4, 2009 | 11:11 PM
DB2-R81's Avatar
25 Year Member
You obviously failed high school physics. Wrong!
Old Mar 4, 2009 | 11:55 PM
mikesrex's Avatar
I guess you are right and I know nothing. It appears that several in this very thread have already indicated real world results backing up my statement along with a few others agreeing with the theory, provided the car is accelerating on the dyno. So we are all wrong and you are right! Congratulations!
Old Mar 5, 2009 | 03:45 AM
b20beast83's Avatar
There are 2 correct answers
they are
YES and NO
Old Mar 5, 2009 | 04:51 AM
flyrod's Avatar
On an inertia type dyno, or a dyno pull that covers the RPM band fairly quickly, yes.
Old Mar 5, 2009 | 05:59 AM
I think the bottom line is that it is in fact a good modification and will make your car faster. And isn't that what everyone is really looking for? Or do people just look for higher numbers on the dyno? I think the latter prevails on this forum!
Old Mar 5, 2009 | 08:19 AM
ddd4114's Avatar
You even quoted it...
Old Mar 5, 2009 | 08:24 AM
SOHCinWA's Avatar
There is a lot of weight loss to an engine that is not seen on a dyno... But thats not to say that it doesnt help get down the track quicker. It just relieves stress on the engine, thus making it more efficient and reliable.
