Maintenance Rqrd - 04 CRV
Sit in the driver's seat with the key off. Using your left hand, reach in to the gauge cluster to press and hold the Select/Reset button (the one on the right, next to the odometer). While you're holding the button down, use your right hand to turn the key to position II (but don't start the engine). Continue holding the button down, and the light should go out after about 8-10 seconds. That's it.
