B20 done... Feedback please *pic's*
After a long hard struggle my car is finished. Had the car tuned and I am happy with the peak Hp but I feel like my car is lacking torque in the mid range and on top. Can you please help me and give me advice to fix this problem. People I spoke to think I must swap my cams for Skunk2 tuner2's??? Also please give me your views and comments on my build good or bad….
Specs of the build:
B20Z sub assembly
B16 head
BC4 cams
Blox Velocity Stack
Precision 440cc injectors
Walbaro Fuel pump
Omni valve train
Endyn 12:1 pistons
Eagle rods
Golden Eagle sleeve brace
GSR girdle
Skunk pro manifold
Skunk 68mm TB
Hytech copy – small tube
BC exhaust
Dicktator stand alone ECU (Locally made engine management system)
Think that's that.
The car made 173.4kw (233hp) and 210nm (154.9). It makes more peak power than any other B20’s in the area but the mid range power is less with +- 25nm (18.44).
*Did conversion from kw to hp hope it's correct*
The car in question
Hytech copy
Motor out
Sleeve Brace Welded
GSR girdle fitted and modified
Sub assembly done
Motor in
Dyno
Results
Specs of the build:
B20Z sub assembly
B16 head
BC4 cams
Blox Velocity Stack
Walbaro Fuel pump
Omni valve train
Endyn 12:1 pistons
Eagle rods
GSR girdle
Skunk pro manifold
Skunk 68mm TB
BC exhaust
Think that's that.
The car in question
Hytech copy
Motor out
Sleeve Brace Welded
Sub assembly done
Motor in
Dyno
Results
nice build. In my opinion as I just finished building mine and its very similar to yours....but I went with 12.5 pistons from CP.eagle rods, stage 4 Buddy club cams, Ferrea valvetrain, port and polish, Edelbrock Victor X mani, DC sport Type R header, custom 2.5" exhaust, stage 4 6 puck clutch, 550 injectors (little overkill, but turn down fP), Skunk 2 Cam gears, and a chipped p72 per chrome and still awaiting to get it street and dyno tuned. Very small differences and i'm crossing my fingers for 240-250.
whats wrong with the bc4 cams, basically a tuner2 with a more agressive primary lobes.
you may want to re-consider using that all aluminum pulley. get a bigger exhaust and that thing will wake up.
But the OEM pulley IS a harmonic balance. If you look at the front, you can clearly see a rubber isolator. And if you look on the back-side, you can clearly see the intertia ring surrounded by rubber on both sides....
i had the same pulley for a little while. the alumnium pully has no form of vibration/harmonic absorbsion, like a oem, ati or the fluidamper. go ahead use the unothodox, i dont care isnt my motor, it was just my opinion/advice. i just use a stock pulley.
I used the OEM pulley
your brake booster was on the right making your car a rhd! your car is clearly an ek4 vti, the whether is clearly very nice and it looks like there is a sea or ocean on the background, you had access to an builder and tuner and with all that said there was only a few options, either malta,cyprus,south africa or australia, so I checked your
dyno chart a saw .za and found out it indeed was south africa!
we too have rhd ek4 vti's in cyprus, the best part is cyprus has the best of both worlds, both edm and jdm cars!
thanks conan!
well we cant say his b20z is considered stock now can we? he has almost every step I was refering to within that other thread! he has the gsr girdle,stronger rods,pistons and a blockguard all which I said were needed IMO though! this is why I love his build! lets not turn this thread into pieces and just wish him GL with his car and build!
The rubber ring on the stock pulley is for harmonics as in under the hood noise. It has nothing to do with engine balance whatsoever as hondas are internally balanced.
I was told that if you run a cold air intake it will get you more mid power, not sure on that. I have the password intake and mine was the same mid. So im going to try a aem short ram with a velocity stack.
interesting
nice build
my setup is nearly the same as yours...also B16 Head (no headwork), Skunk Stuff and so on...only differences are the cams ( Crower S2 ) and the Intake (AEM V2)
my engine puts out 169.9 Kw (231 hp) and 223 Nm (171,9 ftlb)
my next cams would be S2S2, RM M22 oder Endyn Bumpstix
nice buildmy setup is nearly the same as yours...also B16 Head (no headwork), Skunk Stuff and so on...only differences are the cams ( Crower S2 ) and the Intake (AEM V2)
maikito
11
May 30, 2012 07:16 PM
assembly, b20, b20z, bracing, cape, capetown, conversion, convertion, engine, honda, pulleys, sale, sleeve, subassembly, town, underdrive
