Fully built B18C f/S
Hes is a list of whats done to it. its a jdm B18c. 4500 obo. If price is right i will throw in a msd and 2 step setup. its in my car running right now. buyer can come see run. Text me if interested 848-467-9441. located in central new jersey
B18c Engine
Srp pistons 12.5.1 comp 81mm
EAGLE rods
Fully balanced bottom end
line honed
Acl Race Bearings
ACT 12 lb flywheel
ACT heavy duty pressure plate
ACT 6 puck sprung clutch
Type R transmission with heat treated gears and jdm type R final drive and new syncros
Innovative engine mounts for Integra and 92-95 civic chassis
Golden eale block Guard
New Water pump and Oil pump
Ported and Polished head by Eddy's Valve Grinding
Skunk2 Valves
Skunk2 valve springs
SKunk2 retainers
Skunk2 Pro 1 cams
Skunk2 Red Ajustable cam gears
Tri Y headers
Edelbrock VictorX Intake manifold
Skunk2 68mm Throttle body
Aem fuel rail
Rc 310cc Injectors
B&m Fuel pressure regulator
Msd Distributor cap and rotor
Ngk spark plug wires
Skunk2 Billet Spark Plug wire cover
Also included. Air conditioning Pump. works very good. power steering pump. b series axles. 95 Gsr obd1 Engine harness.
B18c Engine
EAGLE rods
line honed
Acl Race Bearings
ACT 12 lb flywheel
Skunk2 Valves
SKunk2 retainers
Skunk2 Pro 1 cams
Tri Y headers
Aem fuel rail
Rc 310cc Injectors
Sonic Motor
Performance
116
Apr 21, 2011 12:40 PM
