Headlight dirty....how to fix??
Old Aug 11, 2002 | 01:10 PM
Dan GSR's Avatar
Default Headlight dirty....how to fix??
One of my projection lens's are dirty. the glass itself looks foggy....how can I clean it?
Old Aug 11, 2002 | 01:24 PM
Q-OnE's Avatar
Default Re: Headlight dirty....how to fix?? (Dan GSR)
if its fogging up in like cold weather, that means you have a leak somewhere. first you can get a heat gun and open it up and clean out the inside. then try to get a hold of a c-clamp and re attach it while heating up the glue again. re seal with caulk and then your set.
Old Aug 11, 2002 | 01:49 PM
Dan GSR's Avatar
Anyone know a how to step by step of taking out the headlights?
Old Aug 11, 2002 | 02:19 PM
Tweakmeister's Avatar
get a helms shop manual http://www.helminc.com
if theoutside glass is dirty you can polish it with some automotive grade sandpaper (start at like 1500grit and go to 3000 then polish).
if it's the inside the hairdryer works....
Old Aug 11, 2002 | 07:44 PM
neo1z's Avatar
Default Re: Headlight dirty....how to fix?? (Tweakmeister)
however, you have to remove the whole front end to remove the headlights, correct?
Old Aug 21, 2002 | 09:39 AM
felix17's Avatar
Default Re: Headlight dirty....how to fix?? (neo1z)
Same kinda problem here... think its the inside of the headlight thats dirty... so i know i can try hairdryer to dry it after cleaning, but how to get inside to do the cleaning?? is it as lame as puttin some polish on the end of a stick type of thing and cleaning from the hole where the bulbs go in?
Thx!
nextgtr
18
Sep 9, 2006 10:54 AM
nextgtr
Sep 8, 2006 08:16 PM
Ronin Integra8
Jan 27, 2003 10:08 AM
CivicBoi
Jul 21, 2002 07:30 PM
