need help with my new dizzy
Old Mar 2, 2009 | 03:26 PM
danewjdmrice's Avatar
Default need help with my new dizzy
ok so i been having problem with my new 98 coupe ex...
so i figured out that that someone have did a swap too a
d16z6 im guessing that it had a d16y8 bfor..
so it had the wronge ecu i did the ecu swap to a p28..
and now i know i have the wronge dizzy because the holes from
the dizzy dont even line up with the holes in the housing where the distributor bolts up too.
so now i got the correct distributor for a d16z6 and it bolts up perfect,
but now the wirring from the distributor to the the wirring from the harness of the engine is different look.
this is the old dizzy connector:
http://i28.photobucket.com/albums/c2...0302091614.jpg
i need to make that connector fit this connectors:
http://i28.photobucket.com/albums/c2...Picture021.jpg
http://i28.photobucket.com/albums/c2...Picture022.jpg
is this possible? enyone know what wire go to what?
thnx
Old Mar 2, 2009 | 09:17 PM
Default Re: need help with my new dizzy
anyone some kind of idea?
Old Mar 3, 2009 | 06:09 AM
94EG8's Avatar
Seagull Management
I generally disassemble both distributors and swap the CYP/CKP/TDC sensors.
Old Mar 4, 2009 | 12:23 AM
but i know that the other dizzy is a non vtec so by changing the:CYP/CKP/TDC sensors.
whould the dizzy still be a vtec dizzy or what make the vtec dizzy a vtec?
Old Mar 4, 2009 | 04:59 AM
94EG8's Avatar
Seagull Management
Theres nothing special about a vtec distributor from an electrical standpoint, literally the only difference is the mounting flange.
YangFlavor
Apr 29, 2019 01:53 PM
jawsiiv
Nov 21, 2008 05:43 PM
buildernick
Nov 11, 2008 08:38 PM
harley06
Oct 31, 2006 02:30 PM
jdm_ef9
Dec 8, 2001 07:16 PM
