Soo... Motor Mounts
Soo i guess i'm in need of new motor mounts and I'm not gona lie i dont know much about them. I need a good strong motor mounts, CD7 h22 swaped. Post what you know how you did it all that **** if you want thanks guys,
either polyurethane fill them or get a set for $250 from Explicit Speed Performance
http://www.explicitspeedperformance.net/
good luck!
good luck!
Grab an old tire, cut a piece of the tread and stuff it in the voids in the mount. Trim off excess rubber to make it fit. Steel-belted motor mounts ftW!
If you have an EX, no you need to swap to an LX mounting system which CAN be filled but you need the bracket and mount.
Alternatively get something like the ESP motor mount kit + traction bar setup.
For what?
You're not the OP so I dunno what you're trying to do.
Swapping to the LX setup could be as simple as going to the junkyard and getting both pieces for under $20.
Yeah the rear one booja, I am going to get all new ones tho thanks for answering the axle question. Im giving him a call back tomorrow. So idk what he will do but hopefully hook me up Thanks for your input guys.
