Need help with my b16a...throbbing...
Old Mar 2, 2009 | 09:55 AM
SanyaK's Avatar
Default Need help with my b16a...throbbing...
So i changed the intake manifold on my b16a from the stock to a itr intake manifold and tb combo. I got it all hooked up, started the car, and its revving up to 4 grand and coming back down. revving up, coming down and it keeps doing that. What might be the problem? Hopefully i didnt hook up some tubes to a wrong spot.....
Old Mar 2, 2009 | 10:12 AM
weavertime1's Avatar
Default Re: Need help with my b16a...throbbing...
So you used an ITR throttle body? Most of the time the ITR throttle body is missing the vacuum nipple on the top. Do you have a pic of how you hooked it up?
Old Mar 2, 2009 | 10:16 AM
tallboy69's Avatar
Sounds like a vacuum leak.
Old Mar 2, 2009 | 10:27 AM
blue00sicivic's Avatar
New User
It does sound like a vac leak. Mine was doing that the other day and it turned out to be the vac line coming off the back of the intake manifold going to the cruise control! Good luck
Old Mar 2, 2009 | 11:08 AM
Former User's Avatar
Yeah, check whether all the vacuum connections are hooked up and whether the IM or throttle body gasket is leaking.
Thatssojdm
Aug 8, 2008 08:42 PM
Braco11
17
Feb 12, 2008 12:32 PM
Dirtfall
16
Sep 20, 2005 04:00 AM
RedRex8
May 28, 2003 09:52 PM
JdMcRxSi
Feb 27, 2003 11:59 PM
