Garage sale!!! Great prices! Tons of parts!! Check it! Pics inside!
HERE IS A LIST OF TONS OF PARTS FROM MY GARAGE. IM TRYIN TO MAKE ROOM AND GET RID OF EVERYTHING I DONT NEED...MAYBE U NEED SOMETHING I GOT. CHECK OUT THE LIST AND PICS AND LEMME KNOW....THNX!!!
FOR SALE
more pics bellow parts list...
95 ACURA INTEGRA OEM PARTS:
95 JDM GSR TRANY W/ LSD $600
JDM GSR HEADER W/HEAT SHIELD $125
ABS COMPLETE (HARD LINES, PROP
VALVE, SENSORS, MODULE, PROP
VALVE, BRAKE BOOSTER, ETC) $1100
OEM WING $100
POWER MIRRORS $75
FRONT BUMPER CUT 4 I.COOLER $100
STEERING WHEEL W/AIR BAG $100
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
FLYWHEEL $50
REAR LOWER ANIT-SWAY BAR $50
OEM MUFFLER $50
99 CIVIC SI OEM PARTS:
OEM POWER MIRRORS $75
THROTTLE BODY $100
INTAKE MANIFOLD $150
CAM & CAM GEARS $100
S4C TRANY**see notes bellow*** $400
EXHAUST W/RESINATOR $50
RADIATOR AND FAN $75
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
RADIO HEADUNIT CD PLAYER $100
POWER STEERING UNIT $80
A/C COMPLETE $300
STOCK PT2 ECU $100
OEM SHIFTER $40
OTHER MISC PARTS..JUST ASK!!!
***note: the b16a2 s4c tranny has a bad differential. The tranny does work, but the splines where the axle goes in on the driver side are bad and fluid leaks out, even when the axle is installed. Can be fixed for $300 by local shop..parts & labor. Or can have lsd put in..or u can fix yourself. $450 is way cheap for this tranny…same gearing as type r tranny, just diff final drive.***
AFTERMARKET PARTS:
SKUNK 2 68MM THROTTLE BODY $150
GSR HYPER PRESSURE PLATE $100
EXCEDY STAGE 1 PRESS. PLATE $75
TURBONETCIS T3 60-1 TURBO $550
3” DOWNPIPE W/ FLEX PIPE $125
OBX EXHAUST MANIFOLD $150
REVHARD INTAKE MANIFOLD $225
RC 1000cc INJECTORS $250
T.NETICS EVOLUTION WASTEGATE $150
GOLDEN EAGLE VACUUM BLOCK $40
BLOX FMU (GOLD) $40
MANUAL BOOST CONTROLLER $25
RS TYPE BLOW OFF VALVE $40
3 BAR MAP GM BRAND $50
THERMAL R&D MUFFLER $125
PILLAR W/BOOST GAUGE & H20
TEMP (BOTH ARE AUTOMETER) $100
MISC. INTERCOOLER PIPE $25
JDM GSR HEAD- FULLY BUILT FOR
TURBO BY MIKE LASKEY @ LAKSKEY
RACING. HEAD WORK INCLUDES: STAGE
3 PORT & POLISH, 3 ANGLE VALVE JOB,
MILLED, HOT TANKED, SURFACED, CRACK/
LEAK TESTED, ALL NEW SEALS, SUPER TEC
INNER & OUTTER SPRINGS, SUPER TEC TIT
ANUIM RETAINERS, SUPER TEC TITANIUM
VALVES W/ BLACK NITRIDE OVERSIZED .5
FOR BOOST.
$1800
FOR SALE
OEM WING $100
POWER MIRRORS $75
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
FLYWHEEL $50
OEM MUFFLER $50
THROTTLE BODY $100
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
A/C COMPLETE $300
STOCK PT2 ECU $100
OEM SHIFTER $40
AFTERMARKET PARTS:
BLOX FMU (GOLD) $40
FOR BOOST.
$1800
z06eateR
Sep 4, 2009 07:55 AM
for looking.
