Need Info on AN size fitting for brake and gas line
i want to change some brake line on my car and put SS some hose i dont know the size in AN for the diameter of the line and the fitting size can you help me...
list for a b18c5
1x fuel line (to the fuel filter to the fuel rail)
1x clutch line (to the master to the tranny)
2x radiator hose (what i need to do to put the SS line on the block i have an idea for the rad but on the block i dont know how to do a clean job
4x brake line what kind of fitting i need to srcew up in the OEM Master cilinder and in the PP VALVE
i think its a begin i will change later the oil return and the turbo Preston hose & vacum hose soo the must important its what i have said in the top
list for a b18c5
list for a b18c5
list for a b18c5
https://honda-tech.com/forums/forced-induction-49/fuel-filter-fuel-rail-kit-fittings-avialable-w-black-hose-2139963/
We also carry a clutch line kit that goes from the master cylinder to the slave cylinder.
https://honda-tech.com/forums/performance-45/clutch-line-kits-2334574/
For the radiator line kit you will need to weld -16 male aluminum bungs to the radiator and to the housings on the block. We have a kit for this also.
