What injectors to use????
Old Mar 2, 2009 | 05:23 AM
christian7750's Avatar
Default What injectors to use????
Say i am gunna get about 230hp to 250hp, what size injectors should i use? Im thinking 370CC Rc's, does that sound right?
Old Mar 2, 2009 | 08:25 AM
Schister66's Avatar
Man U FTW
Default Re: What injectors to use????
The general rule is 5cc/whp. Using that equation you can figure out the amount of total injector flow you'll need for your power goal. Keep in mind, this is just a guesstimate to get you close.
250whp x 5cc/whp = 1250cc total
1250cc / 4 injectors = 312.5cc
That means that you should be good with a set of 370cc injectors; however, i would go with a slightly bigger injector than you think. You always want to leave a little leeway so that you dont limit yourself on the dyno. I would suggest a set of RC440s or DSM 450s. That way if you want more power in the future, you have enough injector to meet your needs. When i built my first setup, i was aiming for 300whp and got a set of 550s. They worked nicely and idled fine. You dont have to concern yourself with lumpy idle if you go to a good tuner. I'm now running 1000's in the spring...they may be a tad lumpier than stock, but a good tuner can make it work.
Old Mar 2, 2009 | 03:04 PM
Anyone else?
Old Mar 2, 2009 | 03:07 PM
EJ1_Ex's Avatar
yes 370 should do you just fine..
mtber
Oct 20, 2009 03:45 PM
xander1100
Jul 2, 2009 06:49 PM
mtber
170
Nov 18, 2008 03:42 PM
Sketch_hs
Nov 13, 2005 10:33 AM
no show all go
Feb 10, 2002 11:59 PM
