How do i keep power steering (((searched)))
Like the title says, I want to keep my power steering. Before I get flamed... I did search and this is a daily driver and it already has a power rack so I figured I will keep it. I have a 92 dx hatchback, I swapped in a 93 LS motor B18A1. The original civic pump is to big for clearance, and the B18 pump would work if the power steering line was he same but they have different male and female connectors. Does anyone have any information, I have searched and found nothing but how to delete the power steering. Again this is a 92eg hatch with a B18A1. Please tell me what pump and brackets I need and what feed line if applicable. Thanks H-T
Thanks guys now do I need just the pump or the brackets as well? Also is the code a P30 because i believe that are all the same from the del sol dohc as the civic si pumps are. i believe there run the generic code of P30. So I ask do I just need the pump, or the brackets as well.
P30's not going to work. You need P75 brackets to bolt up to the non-VTEC head.
As for the pump, any 94-97 Integra pump will bolt right up to the PSP fitting on an EG. I'm selling one on ebay. Bid, or just look at the picture of the fitting to verify. http://cgi.ebay.com/ws/eBayISAPI.dll...m=220370786941
Yeah you need the bracket for your head and this thread should help even though it is not a 6th gen https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
Thanks guys, so your saying i need the A1 top bracket or both? i have them both and either a dohc delsol pump or a 94-97 integra pump? and either one of these will fit the eg hard line for the PS? Thanks for the info
Check the pics and then check your hose fitting to make sure before you buy another pump. It's real simple to check, just undo the 2 bolts and pull the hose up.
A1 or B1 bracket will work. I know B1 bracket is stamped P75. A1 bracket is probably stamped PR4.
Cool man so your saying all I need is the 94-97 pump and i can use the mounts from the A1 and the P/S line from the 92 thanks guys you helped me a lot
d15DEELSOL
Aug 10, 2009 06:49 PM
