Accord matience button
Old Mar 1, 2009 | 02:21 PM
h23vtec_dc2's Avatar
Default Accord matience button
this is my bro in laws accord... i know where its at on integras but not accords. its a 94 accord. matienence red light came on and how do it get it back to green. thats all, prob requires doing something different, but let me know
Old Mar 1, 2009 | 02:36 PM
GhostAccord's Avatar
Default Re: Accord matience button
There should be a slot in the center of the gauge cluster. You push the button in with a key/flathead screwdriver. And you will see it roll back to green. It's nothing electronic, it has a set of gears that roll in conjunction with the odometer.
*Edit
The maint. req. reset button is highlighted in yellow.
Old Mar 1, 2009 | 02:53 PM
tamadrummer1120's Avatar
nice jdm cluster
Old Mar 1, 2009 | 02:57 PM
Targa250R's Avatar
be professional
Originally Posted by tamadrummer1120
nice jdm cluster
It's Canadian.
JDM clusters don't have mph markers inside the km/h markers . . .
Old Mar 1, 2009 | 02:59 PM
oh ok. thanks bro. learn something new everyday.
Old Jul 9, 2011 | 03:18 AM
louvett77's Avatar
I have a 94 accord lx manual How can I remove an srs light....
Old Jul 9, 2011 | 06:08 AM
You will have to retrieve the SRS code that is being stored on the ECU. You retrieve them the same way you would retrieve the check engine diagnostic codes. Stick a paperclip in the blue 2 pin connector mounted under the glove box. Then with the code telling you wat is wrong. Hopefully you will be able to fix the issue with the SRS system. Or you could remove the gauge cluster and remove the bulb.
ejkisling
Mar 19, 2014 04:15 PM
bakerskater11
Dec 10, 2009 08:34 PM
'94gsR
Apr 18, 2005 03:07 PM
FSTASNTZ
Dec 14, 2004 07:43 AM
itchy
Apr 30, 2002 11:44 AM
