Best b16 mod for $1500?
Old Mar 1, 2009 | 01:30 PM
david236kEG's Avatar
Default Best b16 mod for $1500?
Bought a stock del sol VTEC, have 1500 put into it, don't have the time, tools, or garage to do the work, so i pay for labor.
-ebay turbo kit?
-type r cams, header, and tune?
In order to have a dyno tune done, i need a piggy back system like a hondata s300 right?
Old Mar 1, 2009 | 01:35 PM
Evil Ryu's Avatar
Default Re: Best b16 mod for $1500?
build a b20 shortblock
Old Mar 1, 2009 | 01:39 PM
datkidjavi's Avatar
i rather buy a b20 and make it a b20 vtec then sell the b16
Old Mar 1, 2009 | 01:43 PM
EFinawesomeman's Avatar
..But he'd need the head for a b20/VTEC swap.
Old Mar 1, 2009 | 01:44 PM
Ya Digg's Avatar
motec exhaust
Old Mar 1, 2009 | 02:03 PM
brutekiller787's Avatar
boost it. piece your own kit together and put it on yourself. send out your oil pan if you don't feel comfortable tapping it. the rest it simple nuts and bolts.
Old Mar 1, 2009 | 02:08 PM
SuckMyDOHC's Avatar
save up some more and buy a supercharger or just use that money for a good suspension setup and bolt ons.
Old Mar 1, 2009 | 02:12 PM
batallic's Avatar
just get good suspension, ebay kit no way, or u can go b20/vtec or ls/vtec
Old Mar 1, 2009 | 02:43 PM
thumper64's Avatar
B18 conversion. No replacement for displacement.
Old Mar 1, 2009 | 02:49 PM
Colby71's Avatar
Nitrous kit and the tools to put it in with i/h/e. or suspension.
Old Mar 1, 2009 | 02:56 PM
92civicx's Avatar
nitrous+supespension(tires,traction bar,ect)...
Old Mar 1, 2009 | 03:38 PM
brandonEM1's Avatar
dont buy ebay ****. unless you want your car to be whack
anyways, good luck on your new sol
Old Mar 1, 2009 | 03:45 PM
teamworxek9's Avatar
for 1500 id get suspension as well. sae wats left over for a greddy turbo kit.
Old Mar 1, 2009 | 04:08 PM
Volumetric Efficiency. honda people should know this most of all.
Old Mar 1, 2009 | 05:15 PM
Deetz's Avatar
Crazy Honda Guy
Lightened flywheel, lowering springs,used forged rims and some sticky tires
Old Mar 2, 2009 | 01:36 PM
so i guess its not worth my time to do cams? how many times can you spray a 75 on a b16 before it wears out
Old Mar 2, 2009 | 01:38 PM
teggsr925's Avatar
definitely piece a kit together urself, it can be done for less than 1500 and will provide a ton of fun
Old Mar 2, 2009 | 02:56 PM
00whiteek's Avatar
buy 4 d series engines and a nitrous kit and spray the **** out of it, then replace engine and repeat.
Old Mar 2, 2009 | 04:36 PM
Colby71's Avatar
You can spray a b16 all day. Get some plugs and pull a couple degrees you could run a 75 shoot.
Old Mar 2, 2009 | 04:48 PM
koa's Avatar
koa
spray it,bigger injectors,and a dyno tune. thats about 1500.
Old Mar 2, 2009 | 04:58 PM
leoaa777's Avatar
Boost or suspension. /thread.
Old Mar 2, 2009 | 05:37 PM
lee0149's Avatar
if it was me i get some ctr cams $350
suspension upgrade $500
race header $400
i/e $150-250
and a tune $50-150
bam 160 whp to 170whp
Old Mar 2, 2009 | 05:38 PM
lee0149's Avatar
and the motor will last longer than any turbo boost or nos kit
Old Mar 2, 2009 | 05:41 PM
bossm's Avatar
race header $400
i/e $150-250
and a tune $50-150
k you must be smoking right now to think that a b16 is gonna make 170whp with ctr cams and a race header i/e but anyways op i sprayed 75 shots in my b16 got cooler spark plugs and retarted the timing 2 deg and ran 5 bottles threw the car before i took it out and sold it and the car still running right now owww and also i ran a walbro fuel pump it was 75 dry shots
Old Mar 2, 2009 | 06:02 PM
projectwheelspin's Avatar
BOOST .....greddy single cam kit with ebay b16 manifold sell the e manage and d16 manifold and get a vafc....walbro fuel pump if you do it that way youll save a ton
