Nut size??
Old Mar 1, 2009 | 12:45 PM
JONESER's Avatar
Default Nut size??
Anyone know what size the rear hub nut is? My Helm's manual says it's a 22mm x 1.5mm but there is no way a 22mm is gonna fit that nut.
Here's a pic of the nut with me holding a 22mm socket up to it.
Here's a pic with a 32mm socket....
Old Mar 1, 2009 | 12:47 PM
sublime423's Avatar
Default Re: Nut size??
32mm
Old Mar 1, 2009 | 12:59 PM
JONESER's Avatar
Originally Posted by sublime423
32mm
Nah, the 32mm is still too small.
Old Mar 1, 2009 | 01:43 PM
sublime423's Avatar
it should be 32mm for the rear
Old Mar 1, 2009 | 01:56 PM
redbull-1's Avatar
36 mm.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1997-accord-brakes-tutorial-1281812/
Old Mar 1, 2009 | 01:57 PM
GhostAccord's Avatar
36 is the front. It should be a 32mm, I just went into my garage and put an 1.25" socket on it and it fit fine.
What vehicle did this knuckle/spindle come from?
Old Mar 1, 2009 | 02:05 PM
redbull-1's Avatar
Yeah, I'm guilty of not looking too closely at his pictures, and having a drink right now. It's raining where I am and I'm a little bored at home.
Old Mar 1, 2009 | 02:09 PM
all is good, It's snowing here, and I'm just sitting here next to the fire with my laptop and a Guinness passing time too. I probably have a slight advantage where my garage is attached to my house and it just so happens to contain a fully stripped Accord. I can pretty much measure anything in a matter of minutes
Old Mar 1, 2009 | 02:10 PM
Targa250R's Avatar
be professional
When the manual lists the size of a bolt or nut, it's the stud diameter, not the head/socket size.
Old Mar 1, 2009 | 04:30 PM
JONESER's Avatar
My 32mm is too small, 1 1/4" is too small also. It's the rear drum set up from my '91 wagon. I did the rear disc converion about a month ago.
I suspect that the bearings in the disc set up are bad and I wanna use the bearings from the drum setup.
Old Mar 1, 2009 | 04:44 PM
OK so given the information that the drum in question is from a wagon. I would say you have the 24mm diameter spindle, and I would assume that would probably need a 34mm socket.
Old Mar 1, 2009 | 06:37 PM
JONESER's Avatar
Cool, I have to buy a 34mm I guess....
THANKS!
Old Dec 18, 2009 | 04:32 PM
LawlessOne's Avatar
Did you find out for sure if it's a 34mm? I know I just tried a 36 on my 93 lx w/drums and it's too big
Now I need to get a socket to fit it. Can't wait till I get all this #@#$ back together.
O and J Performance
Nov 7, 2008 09:37 AM
ZCHF
Honda Motorcycles
Apr 23, 2006 05:59 AM
Hondata
Mar 24, 2004 07:07 PM
