B16a USDM CA SMOG Parts
Does anyone here know anyone or where i can the del sol b16a USDM parts i believe its the intake manifold with all sensors attached, throttle body, fuel rail. So far i have only been able to get an ECU off of ebay P30-A00. I have a JDM b16a in my crx and am trying to get it bar'd. If anyone has any info or know where i can pick up the parts please let me know thanks.
Or you can just buy the Skunk2 intake manifold. I know they have CARB EO numbers for the manifolds for GSR, ITR and Si, but not 100% sure about the Del Sol.
You don't need the fuel rail. You can get away with the throttle body also since there's no emission sensor hooked up to it on the b16. You do need the evap purge cut solenoid valve, which costs about $150 from the dealer, but you can just go to a junk yard and pull one off from any 92-95 civics.
DrAwoH
Mar 11, 2002 08:04 AM
