need help bearing oil clearance and ring gap,crank end play
Old Feb 28, 2009 | 07:38 PM
promotor's Avatar
Default need help bearing oil clearance and ring gap,crank end play
im planning on building my ls vtec with stroker kit 95mm,i been building my own engine with honda specs but i never built one with stroker kit high comp i also have a ARP mainstud for the main i just need some info on the bearing oil clerance,ring gap,crankshaf endplay.thanks
Old Mar 1, 2009 | 06:07 AM
blackeg's Avatar
Default Re: need help bearing oil clearance and ring gap,crank end play
if you use the arp mainstuds it is to my understanding that you need to align hone the block. for the other specs, all are found in the helms manual or literature that comes with the pistons etc that you buy
Old Mar 1, 2009 | 07:48 AM
98vtec's Avatar
moderator emeritus
i would use the bearing clearance needed for an engine that revs like a true vtec motor and not an LS.
you will, in fact, need to have the mains line honed if you get the main studs. You dont really need them anyway.
Old Mar 1, 2009 | 12:17 PM
promotor's Avatar
but i already bought the main studs,so just get the main caps and get it honed is that what you mean?
Old Mar 1, 2009 | 12:32 PM
promotor's Avatar
i guess i should just used my oem main bolts.
attica
19
Sep 30, 2010 03:28 PM
DC_Legacy
Apr 22, 2008 02:17 AM
DC_Legacy
10
Feb 3, 2008 07:03 AM
N20civicB18
Jun 24, 2006 10:50 PM
costar
Mar 3, 2006 09:53 PM
