can i reuse my oil pump
Old Feb 28, 2009 | 06:12 AM
Evil Smile's Avatar
Default can i reuse my oil pump
hi
my oil pump housing is scored inside a bit. can i reuse it or should i buy a new one?
Old Feb 28, 2009 | 06:28 AM
Natural Aspirations's Avatar
Default Re: can i reuse my oil pump
A new one is $100 and you want to risk your entire motor on an iffy part?
Sure go ahead and use it...............
Old Feb 28, 2009 | 06:43 AM
2fastGSR's Avatar
King of the One Liners
I miss the days when i only had to spend 100ish on an oil pump . . .
If you are questioning it , you are better off replacing it
Old Feb 28, 2009 | 07:37 AM
VTECJUN's Avatar
Agreed!
Old Feb 28, 2009 | 11:37 AM
racebum's Avatar
i also agree with the others. do not cheap out on oil pumps and timing belts.
Old Feb 28, 2009 | 12:06 PM
98vtec's Avatar
moderator emeritus
if the housing, outer and inner gear meet clearance specifications then its fine.
xyk
Jan 6, 2010 08:00 PM
garagespecial
Apr 26, 2003 01:16 AM
PROFILES2000
Feb 25, 2002 01:17 PM
