Idle HELP!
Old Feb 27, 2009 | 05:21 PM
Turbo_DelSol's Avatar
Default Idle HELP!
I have an 89 civic DX converted to OBD1 with an OBD2 b20b motor. Using OBD1 LS ECU. I just checked my idle/air control valve, replaced it with a good one, checked my timing and the darn thing idles up and down. Please help, it is getting on my nerves.
Old Mar 2, 2009 | 07:31 PM
Default Re: Idle HELP!
No one has any ideas? I just need some ideas to look for. I just checked all my sensors and they are good. Could it be in the ECU?
Old Mar 2, 2009 | 07:32 PM
type r teggy's Avatar
do you have enough anti freeze?
Old Mar 2, 2009 | 08:38 PM
that was the first thing I checked. I even did a complete coolant change and made sure it was completely full with no air.
Old Mar 3, 2009 | 08:29 PM
hpi247's Avatar
could be a vacuum leak.
when does it idle up and down? all the time? when the car is cold? when its warm?
Old Mar 4, 2009 | 04:45 AM
kyden's Avatar
what tb are you using?
Old Mar 4, 2009 | 11:06 AM
kcD!lla's Avatar
check your TB gasket
Old Mar 6, 2009 | 12:39 AM
Whatever came on the 1997 b20b motor. When I first start the car it idles really high and then when it begins to warm up it starts the up and down idle.
Last edited by Turbo_DelSol; Mar 6, 2009 at 12:41 AM. Reason: needed to add in another reply
sleepers91hb
10
Apr 5, 2012 10:30 PM
b16_civicjosh
May 10, 2011 07:38 PM
xxi2icexx
Apr 6, 2009 09:50 PM
es.roadster
Jan 24, 2009 11:19 PM
track_assassin
Jan 22, 2008 10:51 AM
