96 accord steering rack and pinoin
Old Feb 27, 2009 | 02:49 PM
movalsb951's Avatar
New User
Default 96 accord steering rack and pinoin
i need to find a how to guide on changing a 96 honda accord 4 clyd automatic steering rack and pinion i got an idea of what im doin but i wana make sure i got every thing i need i already bought the new rack with the inner and outer tie rod ends on it any help i would appreciate thanks SB
Old Feb 27, 2009 | 06:21 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 96 accord steering rack and pinoin
now that the new search is up and working do some searching. Search for things like "steering rack" and other phrases like it. Also search for phrases like "curb damage" and things similar.
the search for curb may not be obvious but I recall discussion like this in threads like that because of the damage from hitting a curb.
I know I've posted this info a few times before, so search and see if you can find it. If you cant find it I'll try posting back with some info.
Old Feb 28, 2009 | 10:41 AM
movalsb951's Avatar
New User
thanks man i look into it an see what i can find
Old Feb 28, 2009 | 07:54 PM
sublime423's Avatar
http://tor.in.honda.com/Rjanisis/pub...096S17044A.PDF
Old Mar 1, 2009 | 11:31 AM
movalsb951's Avatar
New User
thanks alot sublime 423 i was searching everywhere for something like that i really appreciate it now just got to find time to do
Old Mar 1, 2009 | 11:34 AM
sublime423's Avatar
no problem, don't forget to use only "honda power steering fluid"
Old Mar 1, 2009 | 11:42 AM
movalsb951's Avatar
New User
alright man il keep that in mind thanks again
Old May 21, 2012 | 12:22 PM
Slammed95Cord's Avatar
any way to reup this link? i need this im changing the steering rack on my 94 EX today
Old Apr 20, 2013 | 02:45 PM
phsshp's Avatar
I've tried a few searches but can't find something simple enough to understand. Removing a rack from a 1994 Honda Accord LX. I cannot figure out how to reach the lines. Do you come down from the engine compartment? I removed the fuel rail and can reach in there with a short wrench but don't have the leverage to break the nuts free.
I can't seem to get enough room either beside the rack and up through the hole in the subframe, or reaching over the subframe from behind.
Old Apr 20, 2013 | 03:03 PM
nus_dogg's Avatar
I did one on a '95 V6 Accord, and I broke the nut loose from underneath reaching over the rear sub-frame. I had the car on a hoise, so things are a bit easier, but they are a PITA to work with.
tRex99
19
Nov 20, 2004 04:05 PM
itr1236
Nov 28, 2001 10:00 PM
itr1236
Nov 28, 2001 08:09 PM
