help plz. mini-me help needed
Old Feb 27, 2009 | 10:22 AM
alx_90ef's Avatar
Default help plz. mini-me help needed
ok so my friend wants to do a mini-me swap. on his stock d15.
my question is.
i know theirs something i have to remove. like an oil jet or something.
can someone help me out?
Old Feb 27, 2009 | 10:34 AM
thegoudster's Avatar
Default Re: help plz. mini-me help needed
A simple search will answer your question.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
VERY IMPORTANT: If you have a D15 block (or any D-series block with an oil jet for that matter), you need to make sure that you remove the oil jet between cylinders 2 and 3 when you do this swap. If you don’t, you won’t have VTEC. I forgot to pull the oil jet out the first time. You won’t get a code, your ECU will say your solenoid is fine and everything is working great but VTEC will not actually engage. Make sure you remove the oil jet. I took a screw, screwed it into the oil jet, and then pulled it out with a pair of pliers.
After you’ve pulled the oil jet, you’ll need to sand down the block surface so that no gasket is left caked on the block. (You won’t have to worry about this anymore because hopefully you’ll be using a Y8 metal gasket). If you get shavings in the cylinders, then fill the cylinders with warm soapy water and float the shavings out. You’ll do this by turning the crank over a few times with a 17mm until all the water is out. Make sure that there is NO liquid in the cylinders or head bolt holes when you put the head back on (If there is, you can crack your block when you torque down the head bolts). If you are using the manifolds from your stock motor, all you’ll need to do is unbolt your intake manifold (with throttle body) off of your old head so that you are ready to put it on the Z6 head. It’s only 8 bolts.
Old Feb 27, 2009 | 10:38 AM
alx_90ef's Avatar
https://honda-tech.com/forums/showthread.php?t=554053
dam thank you very much thats really helpfull
10psiLsEf2
Aug 19, 2013 06:15 AM
all-mtr-teg
Sep 11, 2007 05:17 AM
99hatch
Dec 16, 2004 04:02 PM
boosted_dc2
Mar 12, 2003 02:44 PM
KS-R
Jan 17, 2002 01:44 AM
