need main cap torque specs for b16
Outer caps 56 ftlbs and inners are 49ftlbs should do this AFTER you hand tighten them with your fingers... then torq in a crisscross fashion or zigzag...
did you check your bearing to crank and rod clearances?
also just double check with factory specs... call honda up, seel if they will tell you..
B18C5-EH2
Feb 14, 2004 08:24 PM
