91 civic sedan
Old Feb 27, 2009 | 01:32 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default 91 civic sedan
i just had both fresh axel replace on my stock d15b2.its an auto.what can cause the issue?when car is on drive i accelerate up to 2k..rpm or 22rpm same time when gear is shifting outta firts to second gear.. it makes this "vibration" then stop.that the only part it do?any input would help.alrite also how can i tell if the tranny has been swap or not?
Old Feb 27, 2009 | 03:18 AM
~sp33~'s Avatar
EFB055
Default Re: 91 civic sedan
What can cause fresh axles to be replaced? I don't really understand the question.
Old Feb 27, 2009 | 03:25 AM
Genetically Gay
nevermind i guess.you dont know how to read.
greenzchatch's Avatar
Check your motor mounts....
Old Feb 27, 2009 | 03:36 AM
Genetically Gay
you think is the motor mounts?damn,you got a clean hatchback.whats the plan?
Old Feb 27, 2009 | 05:23 AM
~sp33~'s Avatar
EFB055
My reading ability is the last thing wrong with what you've posted.
Old Feb 27, 2009 | 05:57 AM
Yea from past experiences if your car vibrates hard when it shifts from 1st-2nd I'de highly recomend that you check the mounts, and do it fast because if you let it go the tranny will eventually go out...
Easy way to check and see if the mounts are bad is by having someone sit in the car and go through the gears and you stand out and watch the engine and see if it has a lot of movement back and forth when going from D4-D3-2 and reverse.
Thanks for the compliment about the hatch but I'm having problems with it, I blew the ZC thats in it twice and now I'm looking for a d16a6 to swap in its place but not having any luck finding one...
Old Feb 27, 2009 | 01:39 PM
sde780's Avatar
I had the exact same thing happen to me, it was the...nevermind I guess. You don't know how to type
itr#1334
Dec 24, 2008 10:23 PM
kempa'sDA
Dec 18, 2006 11:54 AM
Mrob91GS
May 8, 2005 08:08 PM
DarkCyde SI
May 23, 2003 10:33 PM
enhancedCL9
Mar 23, 2003 11:56 AM
