Stock Rim Size
Old Feb 26, 2009 | 08:04 PM
chiaxi2002's Avatar
Default Stock Rim Size
What size rims will fit my 1990 Honda Accord EX? I have stock rims on them and I am planning to buy new tires for them. What is the size of the rims too? THANKS!
Old Feb 26, 2009 | 08:24 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Stock Rim Size
Read sidewall of current tire?
Old Feb 26, 2009 | 08:34 PM
Targa250R's Avatar
be professional
Should be 15x5.5".
Tire size is molded into the tire sidewall and printed on a sticker on the door jamb or in the glove box. Wheel size is cast into the wheel hubs underneath the center caps.
Old Feb 26, 2009 | 08:37 PM
CiviC 4 life!'s Avatar
Yeah, It will say on the side of the tire.
Old Feb 27, 2009 | 09:21 AM
uberEFtuner's Avatar
The bolt pattern is 110MM by 4 or 110x4. The stock wheels for an LX or DX is 14" the EX is 15". On a civic the max size with NO problems like rubbing is 17". I would safely say that is about the same for an older accord.
Old Feb 27, 2009 | 09:38 AM
Sorry I,m a fuktard today the bolt pattern is 114mm by 4 or 114x4
Old Feb 27, 2009 | 09:46 AM
twkdCD595's Avatar
I have no idea what your saying here.
Stock rims as said above are 15x5.5" wheels, tire size can vary a little but look at the sidewall for what you currently run.
If your wanting to run an aftermarket wheel, the proper spacing is 4x114.3 for accords that year and as long as you pay attention to your offset you can run anything up to an 18" wheel if you would like from what I have seen. Just dont get crazy with the width or offset. Search the accord forum for offset wheel threads for more information about what combination other have posted up.
Old Feb 27, 2009 | 06:07 PM
I had a 91 CRX si that had 18's and it didnt rub at all. (Bling Bling)
Old Aug 9, 2014 | 02:33 PM
ZDOG2KXX's Avatar
I also have a 1990 Accord EX. if the stock size is 15x5.5, will I be able to put on 15x6.5 aftermarket rims without any issues?
Old Aug 10, 2014 | 04:34 AM
Fitz Williams's Avatar
10 Year Member
As it says above, it depends on the offset.
SunriseSunset
Honda Civic (2001 - 2005)
Feb 14, 2024 07:32 PM
DAJones05
May 7, 2006 10:26 PM
sony224422
Nov 23, 2005 04:26 AM
Braco11
Jul 30, 2004 05:01 PM
