Indicators keep blowing fuse.I can only turn left!!?
Old Feb 26, 2009 | 08:04 PM
JDM Lyfestyle's Avatar
Icon2 Indicators keep blowing fuse.I can only turn left!!?
I hope someone can shed some light on this..Its really gettin on my nerves now.
The indicators work fine to turn left, but every time i try turn right, they flash once and blow the fuse, the arrow on the cluster is normal for turning left but when i go right its ery dim,like half as bright.
Also the hazards do not work at all.
I tried removing the bulbs from both front and rear on the right side and it still flashes dim on the cluster but doesnt blow the fuse it just clicks normal speed.
someone please help!!this is getting very frustrating!!
Old Feb 26, 2009 | 08:12 PM
boostatic's Avatar
Default Re: Indicators keep blowing fuse.I can only turn left!!?
its sumthin on that right side circuit..maybe bad wiring..a corroded socket..sumthins causing it to draw too much current..i believe there could also be a short..maybe 2 of your wires going to your socket are touching each other..the only thing to do is trace your wiring..the problems usually at or close to your sockets so open your hood check your bulbs..sockets..wiring..then do the same in the trunk..its somewhere to start
Old Feb 26, 2009 | 08:14 PM
USDMCIVICHATCH's Avatar
well if it doesn't blow the fuse with the bulbs out you have a short on the right side of your car
ChevelleSSLS6
Apr 9, 2009 07:44 PM
Panda hatch
Apr 24, 2006 08:04 PM
Half_BlkandAsn
Audio / Security / Video
Jul 30, 2004 06:29 PM
Dancing is Forbidden
Sep 3, 2003 11:25 AM
LB CRX
Aug 21, 2003 01:45 PM
